H4/ITA Integra f/s
The car is a 1995 Integra RS Shell - lightest shell available, no sunroof, no ABS, cruise control, power locks.
I bought the car in San Diego, CA with 95k miles, and drove it back non-stop to Va with zero issues at all. It had spent its whole life in Southern California with one owner, there is no rust, bent body panels, seized bolts or frame damage anywhere.
Clear title in hand, was street registered until May 05. This was my first season racing with the car, only 7 Honda Challenge races with 3 pole positions and 3 wins. The car has current NASA logbook, no contact or incidents. The car is fast, fun, sorted out with tons of spares. The car will be available for rides @ Summit Point Shenandoah Nov 11-12 (Carguys HPDE) and Test Drives for a serious buyer.
$12k/obo -Will consider offers without wheels/tires/spares as well. Car is located in the Northern Va (DC Metro area)
If interested contact via email at [email protected]
In-Car Video: (video from the latest race will be posted soon)
Pics:
Details:
Engine
Ebay intake Tube, K&N Filter
Comptech Icebox
SMSP Custom B18B1 Header
SMSP Exhaust w/ turndown behind driver
Neptune ECU, dyno tuned by Jack Harris @ P1 Auto
IT/HC prepared Cylinder Head, Justice Racing Engines
Endyn Oil Catch Can, plumbed into breathers on engine block
P/S System Removed, steering rack outlets looped to a breather
Drivetrain
Transmission Rebuilt Sept 05, all new OEM honda seals, bearings, synchros
ATS 4.9 Final Drive
ITR OEM LSD
Toda Clutch
Toda 9lb Chromoly Flywheel
New Axles July 06
Motul Gear300 Fluid Always Used
Safety/Interior
Piper Custom Cage - meets all scca/nasa specs
Piper seat mount with slider - sparco slider/sidemounts, custom base
Sparco Evo1 Seat
(2) Sparco Harness - FIA stamped 2010
Corbeau Forza Passenger seat
Sparco 383 suede steering wheel, Sparco 2" spacer and hub
Autometer Oil pressure warning light (18psi switch in factory location)
ITR shift knob and shift boot
2.5# Fire Extingushier
Suspension
Koni SPSS3 Shocks
Ground-Control Sleeves
Ground-Control Upper Hats (front and rear)
Several Sets of springs - 800, 850, 900, 1000, 1100, 1200lb
Current Spring rates on car are 850f/800r - very neutral and easy to drive
Orijin Motorsport Front LCA Spherical Bushing Kit
Mugen Front LCA 'compliance' bushing
Mugen Front UCA rubber bushings
Hardrace Adjustable Rear Toe Arms (spherical bushing)
Hardrace Adjustable Rear Upper Control Arms (spherical bushing)
Hardrace Spherical Trailing Arm Bushings
OEM Rear LCA's (New Jul 05)
OEM Front Swaybar (21mm)
Hollow Rear swaybar (1.25" x .095") with aluminum bushing blocks and bar arms, Metric Rod Endlinks
Comptech Subframe Brace (prevents subframe tearing with large swaybars)
Spare Swaybars - Hollow 1.25 x .120", Comptech 22mm
OEM ITR Front Strut Tower Brace
Stoptech Brake Lines
New Wheel Bearings, Hubs, Lower Balljoints and ARP Studs Front Aug 05, Rear Feb 06, all OEM Honda
New Tie Rod Ends and Upper Control Arms Feb 06, OEM Honda
Brake Calipers Rebuilt Jul 2006
Front and rear fenders rolled
Recent alignment (laser rack, Curry's Auto), Camber -2.5/-1.0 front/rear, Toe 1/16" toe out/0 toe front/rear
Cornerweight Feb 2006
Wheels/Tires
(8) ATS Comp Lite, 15x7 +35 Offset
(4) Kosei K1, 15x7 +45 Offset
(4) Kumho V710 225/50/15, 16 heat cycles
(4) Kumho V710 225/50/15, 7 heat cycles
(4) Kumho V700 205/50/15 full tread wets - used for one qualifying session (3 laps) and one race at CMP
Misc Prep
IO Port Camcorder Mount
P/S removed, but still have full system in a box for IT-compliance
Lamin-X film on headlights/turn signal lenses
'Soft' front tow strap
"Carbon Fiber" front spoiler - custom modifed into 4 separate pieces, could be patched together and re-used
Spares
(3) Spare Cylinder Heads
Comlete (but dissasembled) short block - crankshaft still in block
Axles - (3) driver side, (2) passenger side.
Distributor - (1) complete and (2) set of internals (coil, ignitor, cap, rotor)
Plug Wires
Plugs
Front Calipers - 2 sets, both rebuilt
Brake lines - OEM
Almost complete set of suspension arms front and rear, several sets of front upper arms
Front Hubs/Spindles assembled
Rear Hubs
Brake Rotors (at least 8 in good condition)
Front Brake Pads (one set of XP10 @ 50%, one set of new PFC Carbon Metallic, one set Cobalt VR @ 20%)
Alternator
Stock ECU - can have socketed and chipped to match ECU in car
OPM LSD
4.4:1 Final Drive Gearset
4.2:1 Final Drive Gearset
Stock Clutch
Stock Flywheel
Stock Airbox
Fuel Filter
Fuel Injectors (4)
Misc Seals
Complete Engine Gasket/Seal Set
Timing Belt/Tensioner
Alternator Belt
Stock Header/Cat
New price - $10k wthout the ATS wheels (tires still included) or Sparco seat (seat base/slider will be included)
