DriverGT5 Posted October 29, 2006 Posted October 29, 2006 (edited) Mustang SBF Stuff: Barry Grant Race Demon GC Carb 650cfm $350 Ford Engine Block, crank, rods, lifters (302 or 306) $50 World Product Windsor Jr iron heads. 58cc. A few helper springs broke and rounded the top of the valve guides. I have replaced everything but the generic valve seals I used sucked and it leaked oil on the valves. Needs a good quality valve seal installed. Also has a small crack between two of the valves from running too hot. Still worked great but I wanted you to be aware of the problem. Heads have new Crane double springs and hardened pushrods come with. $200 Stock Clutch disc (brand new, Mustang Fox) $40 MSD (condition unknown) $10 FR Aluminum rocker covers $50 Edlbroc Intake manifold $75 Random Stuff: Toyota Tocoma Tailgate $100 Toyota Tocoma Bumper $50 Toyota Tacoma Tow Hitch $150 (No hardware) 5 Zigen 17x7 rims & tires (2) $150 Toyota Corolla Engine (spun bearing) $100 Nissan 15x6 factory wheels $50 16 gal rotary molded cell, needs one more fitting. $50 1st Gen (79-85) V8 conversion stuff. Engine & Trans mount, plus custom driveshaft. What you need to bolt a Ford 302 in an '81-85 RX-7. $300 Rubber engine mounts, (hot rod style that fit V8 kit) plus rubber trans mount. $40 Whole kit (mounts & rubber) $325 3" Exhaust (FB RX-7) made to fit MAC Headers into single flowmaster. $125 Hydrolic converion kit to change Ford T5 to hydro clutch for FB RX7. Kit comes with Wilwood master, CNC slave, mount, ss clutch lines, etc. Paid over $450 new for everything. $170 MAC Products shorty headers. Been fixed a few times. Fair condition (typical MAC quality). $40 Mounts, rubber, clutch kit, 3" exhaust, headers, driveshaft; $570 Over $650 seperatly, cost over $1,500 new. Other Stuff 3" latch style harness. Out of date but in great shape! "Y" style so I can't use it for track days. $40 FB Full stock exhaust. Good cats, pickup only. $35 Parts are located in Clemson, SC. Edited January 30, 2007 by Guest Quote
DriverGT5 Posted November 17, 2006 Author Posted November 17, 2006 OK, a lot of people have been asking and this is what I have. Since BG isn't putting part numbers on the carb anywhere I can find it, this is my best guess. Part # 2282010 650 Race Demon General Comp. (I'm saying it's the GC because it has vacuum ports and I know it's either the RR or GC version. I'm 99% sure that this info is correct though) Quote
