944 cup Posted October 30, 2006 Posted October 30, 2006 1987 944 Turnkey track car I. Engine: 1989 2.7 liter w/recent rebuild Performance header Custom bent exhaust w/ bullet muffler K&N cone air filter Turbo oil cooler AC Delete bracket No leaks and no oil burning No DNF's II. Suspension: A. Weltmeister Front adjustable sway bar &drop link kit/ 28mm. B. Weltmeister Rear adjustable sway bar and drop link kit/ 22mm. C. Front Leda individual double adjustable gas strut w/remote gas canister w/custom length and valving. i. Height adjustable perches ii. Coilover 550# Eibach springs D. Rear Leda individual double adjustable gas strut w/remote gas canister w/custom length and valving. i. Height adjustable perches ii. Coilover 500# Eibach springs E. Box welded steel front control arms F. Adjustable camber plates G. Racer’s Edge A-arm spherical bearings, lower torsion tube bushings, banana arm bushings,delrin outer and inner bushings kit H. Carrera 8x16 inch wheels mounted with Hoosier DOT radials, along with a spare set of same. I. 928S4 brake calipers and rotors front and rear w/ Porterfield race brake pads J. Steel braided brake lines. L. Camber strut brace III. Interior: A. 6 point Autopower roll cage Sparco race seats Seat back brace Camlock 5 point race belts Removable steering wheel Custom gauge panel with VDO gauges B. Hot Lap timer C. Wide angle 17†Quote
