924S wheels and spacers
I have not touched my 924S yet but I have a questions.
1. The Rear 15x7 wheels from my 1988 944 with toyo's will bolt right on correct ?
2. To run the late wheels (15x7) on the front require a spacer (what size ?) and longer wheel studs with the stock spring?
3. With the adjustable ride height kit from paragon i can bolt on a late offset 15x7 wheel/225/50 toyo without other changes ?
4. the stock phone dials on my 924S are 15x6 late offset?
thanks
Chuck
YES
Yes not sure how much maybe 5 mm?
Yes
Yes
YES
Yes
Yes
Chuck, the 15x7 wheels I bought from you fine without spacer on the front of my 1987 924S, but I do get rubbing on the springs if I adjust for much more than 2 degrees of negative camber using the stock camber adjustments. Camber plates that tilt the top of the strut/spring in would likely take care of this problem. That said, some spacers to maximize the track width would likely be beneficial for other reasons.
I can verify the rest of the above as well.
