TN Posted October 31, 2006 Posted October 31, 2006 Nuzzo Motorsports is currently building new cars for the 2007 season and is selling its two current Grand-Am Cup ST Class racecars. These cars are very fast and easy to drive as any of our drivers can tell you. If you are looking for a competitive car to race in GAC, SWC, NASA, SCCA, BMWCCA, EMRA or some other series look no further. These cars have set fastest race laps and lead races at Homestead, VIR, Laguna Seca, Barber, Mosport, and Lime Rock to name some of the racetracks, have earned pole positions, and podiumed in the highly competitive Grand AM cup series. Extensive spares packages available including gearbox, spare shocks, body parts, control arms, rotors, pads, axles .you name it. We have available setup sheets, dyno results and data logs from past seasons. You can view photos at http://www.Nuzzomotorsports.com. Additional info is as follows: 2003 MINI Cooper S #20 . New zero time race motor just installed October 2006 . Motec Engine management system and custom harness . 6 speed gearbox with Quaife limited slip diff . Lightweight flywheel with Sach's racing clutch and pressure plate . Moton Triple Adjustable race dampers with remote reservoirs . Custom 17 gal Fuel Safe fuel cell with red head dry break and discriminator valve . Custom Intercooler, Radiator and oil cooler . MM racing sway bars . Radio harnesses with PTT button, radio box and antenna . Fire suppression system: spray nozzles in cockpit, engine bay, and fuel cell area . New harnesses and window net in January 2006 . 2 sets BBS wheels with Hoosier race tires both drys and wets . Ready for pickup now . $40,000/OBO 2003 MINI Cooper S #22 . 4 races on this race motor. Which should be good for 6 more races . Motec Engine management system and custom harness . 6 speed gearbox with Quaife limited slip diff . Lightweight flywheel with Sach's racing clutch and pressure plate . Moton Triple Adjustable race dampers with remote reservoirs . Custom 17 gal Fuel Safe fuel cell with red head dry break and discriminator valve . Custom Intercooler, Radiator and oil cooler . MM racing sway bars . Radio harnesses with PTT button, radio box and antenna . Fire suppression system: spray nozzles in cockpit, engine bay, and fuel cell area . New harnesses and window net in January 2006 . 2 sets BBS wheels with Hoosier race tires both drys and wets . $37,500/OBO Will make a very nice deal for both cars and all spares. Also available is a 2001 Renegade 16ft Toter and Renegade 40ft 3-car stacker . Will consider trade for a larger stacker or semi rig with 3-4 car capacity. Contact: Tony Nuzzo 516-972-3454© [email protected] Quote
