OEM vs. actual
Greg
I have a question about OEM curb weights . What happens when the OEM weight is more that the scaled weight .
Steve
Guys, let Greg finish the rules!
My answer is that it depends.
Depends on if you are taking points for each individual weight reduction item such as removing carpet, removing rear seats etc. and taking the individual points or if you are using alternate weight method.
If points for individual items, then the actual driving weight is as you drive the car, the lower the better.
If alternate weight method, there is a scale. <100lbs is free and you have to take points if your car is lighter than 100lbs under the oem weight.
Joe Craven
not sure what class - waiting for the updated rules
The problem is that my car has an OEM weight of 3560 lb. and I had it on the scales at the last event 3400 lbs.. The only mods as far as weight is concerned is , no cat's , no spair , and different air box , non OEM tires . I don't think this adds up to 160 lb.
Greg used the 3560lb to class the car, so it sounds like you are using the remove item method to reduce weight. IF yes, then you are good to go. Be happy that your car is a bit lighter than the oem weight used to classify your car.
Is your tanks full? Gas, oil, windshield washer. Cats are quite heavy, spare could be too.
  • National Staff
Actually, the weight I have is 3450 lbs. So, I don't know where the 3560 is coming from. Also, I don't know why the car isn't base classified in TTC with the Mach 1. (or at least TTD**)?
Ok so the weight I have is from magazine test . That sounds better as I would like to put bar in the car and use the alternet method , taking out the back seat and lighter wheels and drivers seat .
Dosen't that work out to 11.5:1 in the power to weight ,which is TTC.
Steve
