Piersin Posted November 23, 2006 Posted November 23, 2006 Just wondering if anyone has had success with the autos? Quote
roadracetransam Posted November 23, 2006 Posted November 23, 2006 yes, '05, '06 TTD socal champion uses manual valvebody auto '07 TTC socal champion uses manual valvebody auto and those 2 are pretty much it for all of socal NASA as far as I know Quote
National Staff Greg G. Posted November 23, 2006 National Staff Posted November 23, 2006 '07 TTC socal champion uses manual valvebody auto We'll see about that one, Mr. NoClutch. Quote
Members Shawn M. Posted November 23, 2006 Members Posted November 23, 2006 yes, '07 TTC socal champion uses manual valvebody auto ewwwwwwwwwwwww!!!!! Greg just got called out! Theres gonna be a gun fight!!! No need to reply Greg, get your butt back to work. I think I speak for all the TT guys when I say, no rules, no posting! When the rules are done, you can post again, til then, zip it and work it! Quote
Piersin Posted November 23, 2006 Author Posted November 23, 2006 What is a manual valvebody auto? Does it have a Torque Converter? Quote
MustGoFaster Posted November 23, 2006 Posted November 23, 2006 Typical with a manual valve body auto, the transmission will do what you tell it to. Put it in 1st gear, and it will stay in 1st, until you tell it to do something else, like go to 2nd gear. They have Torque Converter's and everything else an auto tranny does, except they won't shift themselves. Quote
Piersin Posted November 27, 2006 Author Posted November 27, 2006 Any chance they'll make the automatics a -4 mod since it slows you down and eats up horsepower? That's fair Quote
roadracetransam Posted November 27, 2006 Posted November 27, 2006 Any chance they'll make the automatics a -4 mod since it slows you down and eats up horsepower? That's fair I second that! Quote
loudes13 Posted November 28, 2006 Posted November 28, 2006 ...so how many pts for one of those fancy manual valvebody auto's? Quote
roadracetransam Posted November 28, 2006 Posted November 28, 2006 ...so how many pts for one of those fancy manual valvebody auto's? 0 Quote
shotgunslade Posted November 29, 2006 Posted November 29, 2006 For those of us who have swapped our automatics for manual transmissions in cars that were never offered with automatics. Two wit, my 1994 Subaru SVX has a 2004 Subaru WRX 5 speed, how many points would I be assessed. I count 5: Lightweight flywheel/clutch assembly 1 Ring pinion change (final drive ratio change) 2 Upgrade number of gears in transmission, or altered gear ratios 2 The SVX was originally equipped with a LSD and, in fact, I'm using the OEM rear differential. The difference is that the front differential on the WRX is 3.9 to 1 and the rear driveshaft is underdriven, so that the rear differential ratio on the WRX is the same as the SVX at 3.545 to 1 but with the transmission underdrive actually gives a 3.9 to 1 to match the front differential drive ratio. Did I guess right? Quote
National Staff Greg G. Posted November 29, 2006 National Staff Posted November 29, 2006 Only +3 in '07........maybe. Quote
firehawkclone Posted November 30, 2006 Posted November 30, 2006 Only +3 in '07........maybe. I thought we banned you from posting until the rules came out Quote
shotgunslade Posted November 30, 2006 Posted November 30, 2006 For those of us who have swapped our automatics for manual transmissions in cars that were never offered with automatics. I misspoke. Should have written "For those of us who have swapped our automatics for manual transmissions in cars that were never offered with manual transmissions. Quote
