enjracing Posted March 10, 2004 Share Posted March 10, 2004 SEASONED 306 BLOCK (FULLY BALANCED AND PREPPED BY JIM GRUBBS RACING) WINDSOR JR. IRON PORTED HEADS (3 ANGLE VALVE JOB) MANLEY VALVES SVO F 303 CAM SVO LIFTERS SVO PUSHRODS SVO 1.6 RATIO ROCKER ARMS TRICKFLOW FORGED PISTONS CHILDS AND ALBERT MOLY PISTON RINGS CLEVITE 77 BEARINGS THROUGHOUT SVO HIGH VOLUME OIL PUMP FLOW COOLER WATER PUMP SVO RACE LEGAL HARMONIC BALANCER TRICK FLOW INTAKE (UPPER AND LOWER MANIFOLD) 40# INJECTORS SVO 10.5-INCH CLUTCH STOCK FORD FLYWHEEL ALL A.R.P. FASTENERS MSD DISTRIBUTOR MSD IGNITION BOX MSD COIL K&N VALVE COVER BREATHERS 160* THERMOSTAT Motor was only broken in and has had no further running. Excellent motor for adding a blower or to put in a NASA AI car for competition. Selling to put a 408 c.i. crate- motor in my 1994 Mustang road-racer. Injector rails are the only part needed for this to be a turn-key engine. $ 2,000 Firm (704) 763-3808 Ask for Emerson (http://www.enjracing.com) Quote Link to comment Share on other sites More sharing options...
