ooldguy Posted December 19, 2006 Share Posted December 19, 2006 As we have a positive points assesment for being under the NASA approved minimum weight how about , using the same schedule in reverse, a negative assesment for being over weight. This would enable a street driven vehicle to compete more evenly with more fully prepared race cars. Using me as an example there isn't 2-300# to remove compared to full race vehicles that are stripped to begin with. My race day weight ( '96 C4 with a NASA weight of 3350 ) is actually 3488# plus a 180# driver which is an actual race day weight of 3668#. Thought's ? Robert Dudek NASA Midwest Instructor Quote Link to comment Share on other sites More sharing options...
National Staff Greg G. Posted December 19, 2006 National Staff Share Posted December 19, 2006 (edited) Why is the car so heavy compared to the curb weight? Curb weight should include gas, jack, spare, etc. All of that stuff is worth about 100 lbs (of free weight loss) for a big car like a Corvette. Edited December 19, 2006 by Guest Quote Link to comment Share on other sites More sharing options...
warrtalon Posted December 19, 2006 Share Posted December 19, 2006 Not sure which class you're referring to, but in TTS/TTU, there _IS_ a bonus for being above weight that allows you to have a higher effective weight/hp ratio. My race weight in the Evo is around 3350 on a low tank of gas, which gives me back +.1 to help make up for my AWD (-.5). Your 3668 gets +.45. Quote Link to comment Share on other sites More sharing options...
ooldguy Posted December 19, 2006 Author Share Posted December 19, 2006 scout's honor. Just for grins I put the car on the scales at the last at the last MC event this season. That's all this person does is weight's. Quote Link to comment Share on other sites More sharing options...
National Staff Greg G. Posted December 19, 2006 National Staff Share Posted December 19, 2006 Sounds like it might be one of those "rare" cases where the Regional TT Director could waive some points. You should probably e-mail him and cc me. Quote Link to comment Share on other sites More sharing options...
broeli Posted December 19, 2006 Share Posted December 19, 2006 The curb weights can hurt different cars. Take my Evo for example..if I want to run in TTA I'm going to be penalized for 200lbs of weight reduction eventhough I have done nothing besides remove the spare tire and trunk carpet. I have full interior, a/c, etc. and I only weighed 3079lbs when I got corner balanced. Even if I put the spare and trunk carpet back in it'd still be 150lbs under the curb weight. IMO, the listed/published base curb weight for the Evo is on the high side. Quote Link to comment Share on other sites More sharing options...
warrtalon Posted December 19, 2006 Share Posted December 19, 2006 Holy cow, 3079??? My MR is 3175 without me in it with only 1/8th tank of gas, and that's with everything loose removed (jack/spare/floor mats/glove box/tools) and a lot of mods that weigh less than the stock parts. Even an RS only weighs 60 less lbs in stock form than an MR - you being 3079 in a GSR is pretty amazing. Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted December 19, 2006 Share Posted December 19, 2006 use the alternate weight reduction method and start buying carbonfiber/fiberglass/etc panels, strip stuff, etc there is NO reason to not use the alt method sheesh, with a big car like the 'vette you can probably find 50-75lbs in just the wheel and tire combo Quote Link to comment Share on other sites More sharing options...
broeli Posted December 19, 2006 Share Posted December 19, 2006 I agree. I can't figure out why mine is sooo light. I do have other parts that will reduce weight but not 150lbs worth! I have coilovers (-20lbs), open air intake(-3lbs), Hotchkis rear swaybar(-5lbs), and aftermarket exhaust(-25) that took some weight off..about 50lbs. But then I added parts that increased weight..bigger fmic, cams (aftermarket ones are heavier since stock cams are hollow, RMR a-arm brace (heavier than the stock bars)..that's pretty much it for mods that would decrease and add weight. BTW, the 3079lbs was with 1/2 a tank of gas. My stock curb weight HAD to be more in the range of 3180. Quote Link to comment Share on other sites More sharing options...
roadracetransam Posted December 19, 2006 Share Posted December 19, 2006 I agree. I can't figure out why mine is sooo light. I do have other parts that will reduce weight but not 150lbs worth! I have coilovers (-20lbs), open air intake(-3lbs), Hotchkis rear swaybar(-5lbs), and aftermarket exhaust(-25) that took some weight off..about 50lbs. But then I added parts that increased weight..bigger fmic, cams (aftermarket ones are heavier since stock cams are hollow, RMR a-arm brace (heavier than the stock bars)..that's pretty much it for mods that would decrease and add weight. BTW, the 3079lbs was with 1/2 a tank of gas. My stock curb weight HAD to be more in the range of 3180. Don't forget to add your weight to the car. It is competition weight, AKA with driver. Quote Link to comment Share on other sites More sharing options...
