mwwampler Posted March 22, 2004 Share Posted March 22, 2004 At the PCA DE track day at Firebird East my 1986 944 NA's clutch started to slip during the 3rd session. Unfortunately, the clutch is new and has only 600 miles on it. I thought I was ok with the upshift/downshift's not exceeding 4500 rpm. Any thoughts/suggestions would be helpful. Mike Wampler 1986 944 2003 Boxster Quote Link to comment Share on other sites More sharing options...
AZ Coupe Jason Posted March 22, 2004 Share Posted March 22, 2004 good question.. YOu presure plate might not be set right Quote Link to comment Share on other sites More sharing options...
944-Spec#94 Posted March 22, 2004 Share Posted March 22, 2004 My guess is some you got some fluid (oil, coolant, etc) on the friction disk. I have never had a clutch slip. I have done two clutches one in my street 944 Turbo and the other in my spec car. No slip and not hard to do. Sure it takes a while, but no "tricks" needed to install. If it continues I guess you will need to pull the clutch and inspect. Mike Welcome..... Do plan on running spec? So pick out a car number here http://members.rennlist.com/m758/DriverListing.htm Quote Link to comment Share on other sites More sharing options...
