jmeris Posted January 26, 2007 Share Posted January 26, 2007 (edited) NO longer available! Edited February 18, 2007 by Guest Quote Link to comment Share on other sites More sharing options...
jungle Posted January 31, 2007 Share Posted January 31, 2007 i wish these were 5*100!!! How much do they weigh? Quote Link to comment Share on other sites More sharing options...
jmeris Posted February 2, 2007 Author Share Posted February 2, 2007 i wish these were 5*100!!! How much do they weigh? the 15x7.5 weigh just a tad over 12lbs. each Quote Link to comment Share on other sites More sharing options...
Neon2dmaX Posted February 4, 2007 Share Posted February 4, 2007 i wish these were 5*100!!! How much do they weigh? Rota claims about 11.8 lbs. for a 15x6.5. This weight is an estimate becasue the variation in offset can effect the weight. (From my experience, less offset means slight increase in weight.) In any event, I do not recall ever seeing a 15zx7.5 inch size (although it is possible that they made a special run). If you want 5x100, they are available... as least as of this date. Check the Rota (USA) inventory: http://www.rotawheel.com/AVAILABILITY.htm They will usually list the width variations as 1565, 1570, 1680, 1775 etc.; followed by the offset (all positive numbers); the bolt pattern; and the center bore. In the 15" sizes they currently have FB (flat black), GM (gun metal), and RGM (royal gun metal, or GM with a polished lip). The 57.1mm center bore is perfect for a Neon or Fiero. And the good news, the new price is probably around $400 - $500; not too much more than the wheels being offered here. Quote Link to comment Share on other sites More sharing options...
