Trakmnky Posted March 11, 2007 Share Posted March 11, 2007 This will be my first year in TT although I've been running with NASA and HPDE4 for a while. With the new rules if I have to many points for TTA does that put me into TTS or TTU. Power wise I'm below both and the ruling doesn't apply but if I install a couple more mods I'll have to many points to stay in TTA. I have camber plates installed and don't see an entry for them in the classification forms, how many points are they worth or are they just taken for granted now if you're running coil overs? Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted March 11, 2007 Share Posted March 11, 2007 look in the no-points modification section Quote Link to comment Share on other sites More sharing options...
warrtalon Posted March 11, 2007 Share Posted March 11, 2007 If you have too many points for TTA, then you move to S/U/R. Within S/U/R, it's based off weight/hp ratio. If you're above 8.7:1 adjusted ratio, then you'll be TTS, which is the lowest of the unlimited classes. Quote Link to comment Share on other sites More sharing options...
Trakmnky Posted March 12, 2007 Author Share Posted March 12, 2007 Thanks for the replies. I must have missed it when I went through the no points section. I knew from how things were setup last year that TTU and R were after TTA but the TTS definition/section was a little confusing. Thanks for clearing things up. See you at the track. Quote Link to comment Share on other sites More sharing options...
