sb Posted April 6, 2007 Share Posted April 6, 2007 I've been considering removing my dust shields on my '05 stock STI brembos. I currently run PFC 01 or Pagid RS14 pads w/ Motul RBF600 fluid. Stock brake lines. Ti packing plates. Rotor temps post cool-down are often around 1,000F. I've only had a touch of fade once on a tight little road course, but I am concerned w/ all the heat going into the system. Removing the shields will help cool the rotors, but I am concerned about the effect of radiated heat on the components. Notably, possibly boiling the fluid in the lines, damage to the CV joint, etc. If I remove the dust shields, are these components at risk? Should I attempt to wrap heat shielding around them? ...if so, recommendations? thanks Quote Link to comment Share on other sites More sharing options...
BrandonT Posted April 8, 2007 Share Posted April 8, 2007 Removing the dust shields will help a little, but without ducting you will still have a temp issue. I doubt if any components will be effected by doing so. If available, a directionally vaned rotor will work wonders over a radially vaned one. (The former has curved vanes to 'pump' air through the rotor) Quote Link to comment Share on other sites More sharing options...
Renntag Posted April 8, 2007 Share Posted April 8, 2007 I agree with the first reply. I would highly recommend brake ducts. Even if it means losing the fog lamps. This will make a night and day difference. Quote Link to comment Share on other sites More sharing options...
sb Posted April 10, 2007 Author Share Posted April 10, 2007 Thanks for the info BrandonT and Renntag. Will be installing Ducts. Quote Link to comment Share on other sites More sharing options...
