Seat belts
darkintegra
I was wonderin if they will let me use my car at the HPED classes if I have a 4-point harness but they are missing the certification tags?
Well the way the rules are written, No. I would guess not.
It says, stock, or if harness and expired date, must be 5 point and visually in perfect condition.
(this is not directed at Dark Integra, but merely a polite request to everyone)....
FWIW, its really important that everyone read the CCRs. they are in place so we may all participate safely without any confusion. Everyone, if you havnt read the CCR atleast once or twice each season, please do so.
http://www.nasaproracing.com/rules/ccr.pdf
11.4.8 Seatbelts and Harnesses
The seatbelts should be in good condition. No damage may be present on the seatbelts
and they must be the factory configuration. Any harness or any restraint system, other
than factory stock, shall conform to CCR section #15.5, in all respects* except for the
expiration regulations. Harnesses that are expired for racing may be used providing that
they are in at least very good condition. The use of a lap belt without any shoulder
restraint is not permitted. Passenger seatbelts must meet the same minimum
requirements per the CCR as the driver seatbelts if being used by a passenger. Notepassenger
equipment need not match the installed equipment on the driver’s side.
*Aftermarket DOT-certified belt sets, installed to the manufacturer’s specifications may
be allowed. Proof of DOT certification and proper installation is the driver’s
responsibility.
15.5 Driver restraint system
(See diagram at end of section)
1. All vehicles must have a five (5), six (6), or seven (7) point seat belt system. Arm
restraints are required in open cars and cars with: Open T-tops, Open Targa
tops, missing moon/sun roofs, or glass moon/sun roofs.
2. A five (5) point system consists of a three (3) inch lap belt, two (2) or three (3)
inch shoulder belts, and a two (2) inch anti-submarine strap.
56
3. A six (6) point system is recommended for cars where the driver is seated in an
upright (to thirty (30) degrees) or a semi-reclining position. It consists of two (2)
anti-submarine belts in addition to lap and shoulder belts. Note: Current FIA
Approved belt sets with two (2) inch lap belts are acceptable with the six (6) point
system.
4. A seven (7) point system is recommended for seats with more than thirty (30)
degrees of incline. Note: Current FIA Approved belt sets with two (2) inch lap
belts are acceptable with the seven (7) point system.
5. The material of all straps should be Nylon or polyester, and in new or perfect
condition. The buckles should be metal quick release. There should be a
common release for all belts. [Note: Certain Momo brand belts were recalled by
the manufacturer. These are NOT suitable for racing.]
6. The shoulder harness shall be mounted behind the driver and above a line drawn
downward from the shoulder point at an angle of no more than twenty (20)
degrees with the horizontal.
7. The seat, seat holes, and attachments to the seat are not permissible “harness
guidesâ€
