ITAIntegraLS Posted May 8, 2004 Share Posted May 8, 2004 (edited) The way i read the rules it gets me confused. 9.5 A) it says you can use ANY flywheel as long as a stock pressure plate can bolt to it. and its stock diameter. B)Says you can use any pressureplate as long as it bolts up to a stock (unmodified)flywheel. Does this mean i can use a 8lbs flywheel(aftermarket) or a lightened stock one? Please help. Edo Trying to break the sound barrier in my H4 Edited May 8, 2004 by Guest Quote Link to comment Share on other sites More sharing options...
SPiFF Posted May 8, 2004 Share Posted May 8, 2004 Does this mean i can use a 8lbs flywheel(aftermarket) or a lightened stock one? Yup. Quote Link to comment Share on other sites More sharing options...
civicrr Posted May 8, 2004 Share Posted May 8, 2004 Does this mean i can use a 8lbs flywheel(aftermarket) or a lightened stock one? Please help. Yes that is correct. FYI, I am stating this as the NorCal HC leader. Quote Link to comment Share on other sites More sharing options...
ITAIntegraLS Posted May 8, 2004 Author Share Posted May 8, 2004 THANX this means Im getting a free lightened flywhel WOOO HOOOOO. The car is becoming more of a H4 spec than ITA. Quote Link to comment Share on other sites More sharing options...
Grumpy Posted July 8, 2004 Share Posted July 8, 2004 The technical inspector would need a stock pressure plate, clutch disc and flywheel. Taking the sample flywheel to be tested, the above mentioned stock pressure plate and clutch disc must be able to be properly attached to it. Taking the sample pressure plate and clutch disc, they must be able to be properly attached to the above mentioned stock flywheel. That's how I would test them should I be presented a protest. Quote Link to comment Share on other sites More sharing options...
ITAIntegraLS Posted July 8, 2004 Author Share Posted July 8, 2004 Be my guest Im still running stock. Quote Link to comment Share on other sites More sharing options...
FSR-Jones Posted August 28, 2004 Share Posted August 28, 2004 I'm definetly getting a lightened flywheel. Some more clafication though: b) Any clutch and pressure plate may be used so long as it would bolt to a stock (unmodified) flywheel. So this means I can use a different clutch as long as it "would" work with a stock fly wheel. For instance I can get a clutch masters stage 4 clutch because it would work with the stock fly wheel... Is that correct? Quote Link to comment Share on other sites More sharing options...
straywalker Posted September 30, 2004 Share Posted September 30, 2004 I'm definetly getting a lightened flywheel. Some more clafication though: b) Any clutch and pressure plate may be used so long as it would bolt to a stock (unmodified) flywheel. So this means I can use a different clutch as long as it "would" work with a stock fly wheel. For instance I can get a clutch masters stage 4 clutch because it would work with the stock fly wheel... Is that correct? Yah that sounds correct to me. Quote Link to comment Share on other sites More sharing options...
