Steve Rea Posted May 11, 2004 Share Posted May 11, 2004 Ok, more questions...just bought my trailer and want to know what you guys are using to strap down the 944. I've already got my straps and know it's recommended to cross them to make it as stable as possible, but what are you hooking onto in the car? Thanks, Steve Quote Link to comment Share on other sites More sharing options...
Tim Comeau Posted May 11, 2004 Share Posted May 11, 2004 Iwould buy the ratcheting tie down straps that have flat hooks, not the kind with twisted 90 degree flat hooks, nor those other hook types. With the flat hooks, you have the option of going through the wheels. I use the stock towing points on my car, front and rear. Quote Link to comment Share on other sites More sharing options...
944-Spec#94 Posted May 11, 2004 Share Posted May 11, 2004 I don't have a good picture, but... The fronts are pretty easy. There are two loops from the frame rails. These should be pretty easy to spot. The rear requires a little drilling. I when to home depot and got two of the largest round eyelets I could find. Like 3/8 shaft and 1.5" diameter eyelet. I then installed these in the back of the right next to the rear jack points behind the wheel wells. Find round dounut points behind the rear wheels. Here is a reienforced sections of the body. Just aft of this I drilled a hole and simply bolted the eyelet in backed with thick washer in the car. I have on on each side of the car in perfect spots for tie downs and also great for rear tow points. I don't however have any good pictures. Quote Link to comment Share on other sites More sharing options...
Steve Rea Posted May 12, 2004 Author Share Posted May 12, 2004 Thanks guys as always. s Quote Link to comment Share on other sites More sharing options...
