mfoley Posted May 25, 2004 Share Posted May 25, 2004 I'm adding an oil temp guage and a water temp guage to my car. I had the oil drain plug drilled for the oil temp sensor which works pretty well. I'm looking for a good place to install the water temp sensor. Any suggestions? Where do you have yours? Quote Link to comment Share on other sites More sharing options...
jjgrow Posted May 25, 2004 Share Posted May 25, 2004 Mine is in-line on the water hose between the radiator and block. The car's down there now if you want to tell Chris to go look at it. Quote Link to comment Share on other sites More sharing options...
mfoley Posted May 26, 2004 Author Share Posted May 26, 2004 What temp does it read when the factory guage is towards the top? Your guage reads water into the block. I'm wondering what the delta temp is between your location and where the stock sensor is located. Quote Link to comment Share on other sites More sharing options...
