99HOSS Posted June 2, 2004 Share Posted June 2, 2004 2002 Five Star Grand Prix with 3/16 lexan removable rear windows,Townsend Coil over truck arm suspension, all 2000 updates with road racing geometry, left and right side upper a-arms placed correctly,Custom spindles and lower control arms (Tubular),Speedway custom front and rear adjustable swaybars,Chevy small block 350 CI FastBurn engine built by and dynoed by Maryland Performance 370 rear wheel horsepower, great torque curve750cfm re-worked “Legal” Holley Carb,Dynatech equal length headers with 1 muffler exhaust system, HP coated inside and out,Quartermaster disk clutch, 3 races since new, AFCO Radiator with Oil cooler, Canton Road Race Pan and oil system and 3qt Accsump, System one filter, all lines braided steel, MSD 7ALN with MSD coil and Billet Distributor single wire alternator Mini reduction starter, Optima 800 CCA Battery,Quarter master Aluminum Blowsheild, New Jerico 4 speed trans, fresh gears bearings and seals,Winters Quick Change rear, new Seals It seals & bearings, R&P White -Five Star 1998 Pontiac Grand Prix steel body, glass fenders and hood, Plastic windows, Aluminum Spoiler AFCO coil over on all four corners. Adjustable ball joints,All new steering wheel linkage and Borgensen joints and bearings and collapsible steering column. Outlaw 4 wheel disc four piston racing disk calipers with Custom Speedway Wide 5 hubs and Tilton Master cylinders, Brake cooler ducts and hoses installed. Brake re-circulators, Quartermaster hydraulic clutch bearing assy, Basset 15x10 spun wheels/ black with Longacre quick relief popoffs, Steward Warner gauges, Autometer recall tach,new fire system, New Sparco restraint system with SFI roll bar padding,Quick release steering wheel, Richardson Racing Products custom seat,Custom 22 gallon fuel cell with zero gallon center pump pickup (a must for road racing). $21,000 with select spares (Hubs, bodywork, spoilers, wheels, rain tires) $11,000 roller Spares package and Misc: 10 new Speedway swaybars 15 plus sets of Winters quickchange gears Panhard bars Quarter Master driveshaft (new) Tex Racing Detroit Locker- new in box helmet cooling system 7 AFCO shocks 15 springs 3 pump jack A-arms, drag links Calipers Quartermaster release bearing 350HP 2bbl late Model Motor Super T-10 4 speed trans Pit cart Originally built for the SCCS (Stock Car Challenge Series). Car is on the East Coast. Contact Jeff at (301) 236-4940 or [email protected] Quote Link to comment Share on other sites More sharing options...
