PeanutinCA Posted June 21, 2004 Share Posted June 21, 2004 The mellow yellow went on a little diet today. Took out the wiring for the power doors/windows. Plus the horn and AC RESISTORS. All in all I pulled out another 10-12 pounds. I am swapping my muffler to a glass pack because the muffler I have sounds horrible inside the car. That's about another 10 pounds apparently? Does anyone know anything about sunroof weights? My newer cars sunroof seems heavier/more solid than the roof on my older (Jason's) car? They were both electric? At least I think? Certainly the old car had the motor in the back? Unless they swapped it to a manual roof? Because I think the latches were different from memory? But I found this on Rennlist?; The stock panels are indeed fiberglass and weights are: Panel for power sunroof, without hardware or liner - 15.5 Panel for manual sunroof, without hardware or liner - 10.5 They are interchangable as long as you use the proper manual roof latches or some other means of securing the panel. Anyone got an earlier model manual roof? P.Dilly. Quote Link to comment Share on other sites More sharing options...
