National Staff Jeremy C. Posted June 27, 2004 National Staff Share Posted June 27, 2004 The rules read like this. A 3/16-inch inspection hole must be drilled in each of the required bars in a non-critical area for the purpose of determining wall thickness. Does this mean I have to drill a hole in every bar? What places do I need a hole so the thickness can be inspected? I was thinking of not drilling any holes, and just bringing my drill with me to tech so I can put them in where they ask for them! Are there specific spots I can take care of now? Thanks... Quote Link to comment Share on other sites More sharing options...
civicrr Posted June 28, 2004 Share Posted June 28, 2004 I would contact the local regional office to get clarification on both of your questions. Here are my opinions. Keep in mind that I am not a 'tech inspector'. Typically, you will be required to have an inspection hole on the main hoop, a doorbar , a rear diagonal & the forward bar. This will vary by the inspector. They usually like the holes to be drilled prior to the car arriving for tech. Just call (your local tech station) ahead to ask where & what tubes. My interp. of a 'marine case' is a enclosed (box w/lid) case with a vent to the outside of the passenger compartment. Quote Link to comment Share on other sites More sharing options...
SPiFF Posted June 28, 2004 Share Posted June 28, 2004 Here is a good thread on the subject. http://www.honda-tech.com/zerothread?id=906850 civicrr's post is also correct, but again things will be a bit different by region and sanctioning body. Best thing to do is check with the person who will be teching your car to make sure things will go smoothy. Quote Link to comment Share on other sites More sharing options...
Members Ryan F. Posted July 2, 2004 Members Share Posted July 2, 2004 If it is for the LA region, drill one in the vertical bar in the main hoop, the diagonal bar in the main hoop, a single door bar, and one of the rear kicker bars. That should do it. Make sure it is easy to fit a set of calibers in (not right up next to another bar welded to it) and no at a bend. Quote Link to comment Share on other sites More sharing options...
Grumpy Posted July 8, 2004 Share Posted July 8, 2004 If it is for the LA region, drill one in the vertical bar in the main hoop, the diagonal bar in the main hoop, a single door bar, and one of the rear kicker bars. That should do it. Make sure it is easy to fit a set of calibers in (not right up next to another bar welded to it) and no at a bend. ditto for ECHC Quote Link to comment Share on other sites More sharing options...
