crazy_ugly_coyote Posted February 13, 2008 Share Posted February 13, 2008 So if my car is a track only car, would there be any need to keep my dust shields (on the brakes)? They are proving to be a pain when it comes to working on it. Quote Link to comment Share on other sites More sharing options...
Karl Posted February 13, 2008 Share Posted February 13, 2008 I have removed mine they also obstruct airflow to the brakes. Quote Link to comment Share on other sites More sharing options...
nape Posted February 13, 2008 Share Posted February 13, 2008 I have removed mine they also obstruct airflow to the brakes. Not if you cut a hole and weld some pipe to them to connect the hoses for your brake ducts. Quote Link to comment Share on other sites More sharing options...
Renntag Posted February 15, 2008 Share Posted February 15, 2008 There are a couple ways to interpret the original post. Are you referring to the dust cover over your hub? or the backing plate behind your rotor? As to the hub dust cover, I have seen many cars with out this cover installed. As to the rotor backing plate, it is prefered to make this a bolt on unit such that it may be easily removed for servicing the brakes. It is also paramount to duct cooling air to the brakes as mentioned previously. Best of luck. Quote Link to comment Share on other sites More sharing options...
