153bigblock Posted April 10, 2008 Share Posted April 10, 2008 Hello. First time posting. I posted this question over at Rennlist too. I am slowly building my car into a racer and thought I would get some suggestions over here. I have a 1983 Guard's 944. Anyway, I want to eliminate the auto pop-up feature on my car by eliminating the motor, linkage, etc. while being able to manually lift both sides and still use my headlights. Anyone have a suggestion how I can just have buckets with some sort of manual latching up and down of each lamp/lamp housing? Has anyone done this? Thanks. Michael Quote Link to comment Share on other sites More sharing options...
Driver Posted April 10, 2008 Share Posted April 10, 2008 Does it need to look good? Seems like you could lock it down with something like a hood pin, and hold it up with a pin/cotter. Another option would be a drop-in, pull-out ligth assemmbly. Rather than locking it down, you just pull it out and unplug a wire. Quote Link to comment Share on other sites More sharing options...
153bigblock Posted April 10, 2008 Author Share Posted April 10, 2008 I would prefer the solution rest under the hood rather than on top, but that is a good suggestion to consider. Quote Link to comment Share on other sites More sharing options...
RSCoupe Posted April 10, 2008 Share Posted April 10, 2008 Why not switch to a non-popup headlight? Like on the 924GTS race car. Something like this: Quote Link to comment Share on other sites More sharing options...
chris_venturini Posted April 10, 2008 Share Posted April 10, 2008 if he wants to race spec at any point its illegal to use those type of headlights. Quote Link to comment Share on other sites More sharing options...
Driver Posted April 10, 2008 Share Posted April 10, 2008 The simplest thing to do would be: Fine where two peices of metal (moving parts between the light and the frame) are parallel to eachother, drill a hole through them, and insert a bolt. Quote Link to comment Share on other sites More sharing options...
153bigblock Posted April 10, 2008 Author Share Posted April 10, 2008 All good suggestions. Thank you. Yes, I will want to keep it spec legal. Also, cost is a consideration. Hardware store here I come. I just thought someone might have invented this wheel before. Quote Link to comment Share on other sites More sharing options...
Sterling Doc Posted April 12, 2008 Share Posted April 12, 2008 All good suggestions. Thank you. Yes, I will want to keep it spec legal. Also, cost is a consideration. Hardware store here I come. I just thought someone might have invented this wheel before. I did this on my 924S. I cut two pieces of 2x2 wood to fit (very) tightly between the back of the metal framework that sticks out the back of the headlight and the corner between the out fender and the front of the wheelwell. Wedging that wood in there would prop up the headlights, and taking it out would drop them. It was simple, and very effective - no rattling, etc. Just make sure the block fits tight For a while I had the plastic surround around the headlights out, but then the headlight covers would catch air, and open up the headlights up at speed. Where are you from? Introduce yourself on the 944 forum, and over at http://www.944Spec.org - lots of information there! Quote Link to comment Share on other sites More sharing options...
153bigblock Posted April 12, 2008 Author Share Posted April 12, 2008 Thanks Eric. That sounds perfect! Simple, cheap and easy. I will give it a go. Sorry, I didn't properly introduce myself. I am in the LA area (So Cal/Santa Monica). I will check out your link. I hate to impose, but maybe you can snap a couple of digis when you have a chance so I can see exactly what you did. I am spatially limited. Thanks again. Michael Quote Link to comment Share on other sites More sharing options...
