shiners780 Posted April 27, 2008 Share Posted April 27, 2008 I did search, but I am still uncertain. I would like some clarification before I go drilling holes in my cage. I was thinking of drilling one 3/16" hole in each of the following bars: Main hoop Diagonal One door bar One rear stay My questions are 1) is this sufficient, and 2) does it matter where on the tube the hole is drilled? Any other suggestions? Thanks in advance! Edit: Another question is how you determine what a "non-critical area" is? Quote Link to comment Share on other sites More sharing options...
Mike Hurst Posted April 27, 2008 Share Posted April 27, 2008 If you are required to drill holes, drill them about an inch from the end of a tube, at points in the tubes farthest from the driver. I recommend not drilling any holes in the cage until a scruitineer asks you to, carry a cordless drill and 3/16" bit with you just in case. It's 2008, time to stop drilling holes in tubing and tempting someone "add thickness" to the tube at the check point instead of using a tool that can check the tube thickness at any point: Quote Link to comment Share on other sites More sharing options...
Izzy's Cages Posted April 28, 2008 Share Posted April 28, 2008 My only addition to what MH added would be to go a little further than an inch from a weld point. At 1" in, you may still be in the HAZ (Heat Affected Zone) of the weld. Mike is very much right though. We need to stop requiring drilling holes in our cages. Quote Link to comment Share on other sites More sharing options...
vpnwiz Posted April 28, 2008 Share Posted April 28, 2008 FWIW my cage guy drilled the inspection holes in the main and front hoops about midway between the floor and the door bar. He also drilled a hole in the passenger door bar about 2" from the front hoop. He sprayed some clear lacquer around it too, but I am going to go back and probably cover them with silicone caulk. Too many days in the rain already this year. But I'm with those guys above, I don't think we should be drilling holes in cages. Hope that helps. Patrick Quote Link to comment Share on other sites More sharing options...
shiners780 Posted April 29, 2008 Author Share Posted April 29, 2008 Thank you for the responses. Quote Link to comment Share on other sites More sharing options...
