Rook Posted May 25, 2008 Share Posted May 25, 2008 Having recently purchased a used set of Koni DAs I'm trying to learn exactly how to adjust them. Reading the directions online hasn't provided me with a clear answer as far as compression/rebound control. Does rotating the adjuster clockwise increase dampening force...or lessen it? Also, as the tab of one of the adjusters seems to be partially cut off (for some odd reason) I don't know how much range of adjustment I'm dealing with for rebound. Anyone? Quote Link to comment Share on other sites More sharing options...
edhunter Posted May 30, 2008 Share Posted May 30, 2008 Do you see this tuning article... pretty straightforward.... http://koniracing.com/rrtuningguide.cfm Quote Link to comment Share on other sites More sharing options...
Rook Posted June 1, 2008 Author Share Posted June 1, 2008 Yes...that would be exceedingly straightforward....well it would if I knew what kind of adjustment range I was dealing with. As mentioned above, I do not. These dampers have no markings denoting a minimum or maximum position. Additionally the adjustment knobs have no descernable stop at either position. So you can see my problem. Quote Link to comment Share on other sites More sharing options...
sstecker Posted June 2, 2008 Share Posted June 2, 2008 on my koni double adjustable strut inserts (8611). rebound adjuster at top of strut and bump at bottom. this is from memory: looking down at top of strut (rebound)- full clockwise is soft and counter clockwise is firm looking up a bottom of strut (bump) - full clockwise is hard and counter clockwise is soft follow the procedure. mine required turning the front wheels to reach the bottom of strut while in pits. youll have the bottoms adjusted in one session. bump had notches - i started at notch 3 front and rear. think full sweep is on full turn (12 notches think) on bump and 3 turns on top rebound(no notches). a quick call/email to koni will get your answers to which direction your adjustments go Quote Link to comment Share on other sites More sharing options...
Rook Posted June 6, 2008 Author Share Posted June 6, 2008 Thanks man! Totally what I was looking for! Quote Link to comment Share on other sites More sharing options...
