jr racing Posted August 31, 2004 Share Posted August 31, 2004 2001 mercury cougar world challenge car. The car is extremely fast and is now well sorted. Brief specs are as follows: Chassis started as body in white FEA done on chassis and cage design prior to cage being built on surface plate by Technosports in Detroit Custom Autostuff A-arms, camber plates, etc. Custom lightweight motor / transaxle mounts HRP cockpit adjustable rear swaybar Speedway Engineering adjustable front swaybar Lightened sub frame Phoenix 10Lb fire bottle Aeroquip fuel, oil, and brake lines Full range of springs for front and rear 22Gal ATL fuel cell with aluminum can Momo carbon fiber seat Spec Rear Wing Wilwood Superlite 3 front calipers with 12? vented Coleman rotors Wilwood NDL rears Ti or AN fasteners throughout Dynamic triple adjustable struts Forgeline wheels - several sets Engine- $20K Kinetics 2.5L Duratec race engine 290+ HP with dyno sheet. Ford ECU modified by Ford on the dyno for spark, fuel, etc Light weight alternator Headers are custom stainless step headers Setrab oil cooler C&R custom aluminum radiator 3Qt Accusump Aluminum power steering pump and pulley Transmission- MTX-75 with Quaife Dif and Quaife Gear set: 1st 2.643, 2nd 1.824, 3rd 1.400, 4th 1.182, 5th 1.040 4.06 and 4.25 Final Drive Ratios Quartermaster 5.5" 3 disc race clutch Quartermaster lightweight flywheel TDI custom high strength axles Custom high strength inner CV Fixtures, blue prints, wiring diagrams, Mitchell chassis analysis, records. spares: 2 spare racing gear boxes 1 spare racing engine (250+hp) assorted gaskets gear sets 12 wheels custom built stainless steel headers spare brakes all jigs (control arms, engine mounts etc) Asking $30,000 obo cad Quote Link to comment Share on other sites More sharing options...
