Pegasus Racing Posted September 24, 2004 Share Posted September 24, 2004 Great, proven, reliable race car for coversion to AS or Grand AM Cup or use as ITE, NASA, EMRA or club / track days cars. This car was consistently in top 5 in 2002 Grand Am Cup GS series with podiums at VIR, Daytona 6-hour and Mt. Tremblant. Well built, solid and INEXPENSIVE. Complete car for $12,000 call Andrew Kopperl (617) 308-9090 cell (617) 367-8475 office or email [email protected] 400 HP / 400 ft/lbs Torque LT-1 Race Motor by Marv Palmer (Bilmar) and Kim Baker; Roller Rockers, Heavy Duty Internals, Free Flowing Heads, High Flow Injectors; HD Oil Pump, Accusump Oiling System, Ram Air, High Temp Taylor Wires, Race Calibrated Computer, Aluminum Radiator, Hooker Headers, Nascar style side exhaust; Engine designed to operate under endurance race conditions at 5500-6000 RPM. Full Cage with Nascar door bars, window net; OMP carbon fibre seat, OMP suede steering wheel, Helmet Cooler, Auto Meter Oil & Fuel Pressure & Water Temp Gauges, Under driver Heat Shields and Insulation; $3K Wilwood 6 Piston Race Brakes, 1LE PBR also available depending upon needs. $5K Penske Race Shocks with remote reservoirs; Modified suspension pickup points for maximum grip; Heavy Duty Bushings and Sway Bars; ZR1 9 x 17 wheels; Car set up for Hoosier Race Tires; 700 lb springs front / 150 springs rear, adjustable spring perches. Auburn locking differential. Dry Break Fueling with modified Tank to hold 20 gallons. Consistently Maintained to race ready status. Before each event we: freshened rear; changed all fluids; leak down engine - changed and freshened every 4-6 endurance races; rebuilt transmission every season; new wheel bearings every 3 races. Replaced any worn or broken parts. Body is straight with typical small dings associated with a race car. The car is clean, solid and very fast! Quote Link to comment Share on other sites More sharing options...
