JohnC Posted December 6, 2008 Share Posted December 6, 2008 I am gutting the interior, dash, etc on my '95 M3 this weekend, any advise/shortcuts for easy/safe removal of dash, airbags, etc? I'm prepping the car for a cage and everything needs to be removed. Goal is to prep the car for GTS2/3 in 2009. Thanks, John Quote Link to comment Share on other sites More sharing options...
ryan325 Posted December 6, 2008 Share Posted December 6, 2008 Just disconnect the battery before you remove the air bags. To be 110% safe touch the pos. and neg. cable ends together. Then just handle carefully. I also store them with the face up - that way if some freak accident happens and they deploy, they don't get launched! Probably overkill but whatever. Quote Link to comment Share on other sites More sharing options...
cosm3os Posted December 6, 2008 Share Posted December 6, 2008 Your favorite tool to remove the heater core is the BFH. Just go gangsta on it. Quote Link to comment Share on other sites More sharing options...
RSCoupe Posted December 6, 2008 Share Posted December 6, 2008 Keep in mind that anything you remove without damage, you can possibly sell. You can sell almost anything on ebay. It's a good way to augment your race budget. Quote Link to comment Share on other sites More sharing options...
///mracer Posted December 6, 2008 Share Posted December 6, 2008 If I would do it all over again I would KEEP the HVAC and run GTS-2....... Quote Link to comment Share on other sites More sharing options...
dillehayd Posted December 6, 2008 Share Posted December 6, 2008 -Take the windshield out first. It makes working on all the stuff under the dash much, much easier. -Remove the bolts that join the two halves of the door hinges and throw them away. Open the door and lift up and the whole thing comes right off. Your cage builder will thank you. -Use a heat gun and plastic putty knife to remove the tar sound insulation. The adhesive left behind is easily cleaned up with the aerosol version of goof off (it contains xylene which other versions of goof-off do not). -You only need 1 wire going to the trunk for brake lights. -Almost every item in the interior can be sold. My donor car (a 328) was darn near paid for by the interior bits. -Break out the cutting wheel now. It's a lot more difficult when the cage is in. Quote Link to comment Share on other sites More sharing options...
MCain Posted December 6, 2008 Share Posted December 6, 2008 With the airbag, don't do this: Quote Link to comment Share on other sites More sharing options...
bpanther Posted December 9, 2008 Share Posted December 9, 2008 John, Let Kyle and I know when you are ready to start pulling the interior. That is the funnest part of building a car. Quote Link to comment Share on other sites More sharing options...
cstreit911 Posted December 9, 2008 Share Posted December 9, 2008 My advice? If it's not related to steering, braking, or gas then remove it. Quote Link to comment Share on other sites More sharing options...
JohnC Posted December 9, 2008 Author Share Posted December 9, 2008 Thanks all for the suggestions. We pulled all the interior, dash etc. this weekend and made sure the car would run without incident which it did. Need to remove all the window mechanisms, remove the sound deadening material and then cut the inside driver door panels out to make room for the nascar bars. Should be ready for the cage soon. Dave we are doing the work over at Kevins I'll let you know when we will be back to finish the work. Mac Miller dropped by to see the car, he was very helpful. John Quote Link to comment Share on other sites More sharing options...
