Dave B Posted October 18, 2004 Share Posted October 18, 2004 I'm sure some of you folks know the answer. On a 9.5 " wide wheel, which is bigger , the Kumho Victoracer or Toyo RA-1 in 275/40-17 sizes? Ever seen them side by side? Quote Link to comment Share on other sites More sharing options...
Jeff F Posted October 18, 2004 Share Posted October 18, 2004 Well, I can tell you that when I had a stack of 4 Victoracers next to a stack of 4 RA-1's (all 275/40/17 on 9" wheels), the stack of RA-1's was taller. This would of course be sidewall-to-sidewall, not necessarily tread width. I imagne the same would hold true on a 9.5" wheel Quote Link to comment Share on other sites More sharing options...
Keith Posted October 18, 2004 Share Posted October 18, 2004 You can compare the dimensions by going here: http://www.toyo.com/tires/tire_specsheet.cfm?id=1 and here: http://www.kumhousa.com/Products/PtnDetails.asp?mainCatID=1&PtnID=V700 Quote Link to comment Share on other sites More sharing options...
Dave B Posted October 19, 2004 Author Share Posted October 19, 2004 Thanks Keith, Those measurements would imply that the Kumho has 5 mm more tread than a comparable Toyo (0.2"). I am not sure if that is why they are considered faster as I can tell you that at the rear, at least , I am not using all the tread width of the Kumho anyway on 9.5"rims. I do seem to have good use of the fronts with neg 2.5 camber. Quote Link to comment Share on other sites More sharing options...
Keith Posted October 19, 2004 Share Posted October 19, 2004 I personally believe that Kuhmos are faster due to a softer tire compound. I can't imagine 5mm making that much of a difference all by itself. Quote Link to comment Share on other sites More sharing options...
