Monroe Posted October 20, 2004 Share Posted October 20, 2004 Not sure what is going to happen on the job front next year so I'm considering selling the powertrain out of old-n-bused. 395" windsor. Zero balanced. Carbed. Ready to go in whatever dress you desire - ready to fire up or longblock. Makes right at 440/440 at the wheels (A/F set at mid 11's) on mid grade pump gas. Mild Hyd cam. Has had regular 5-7 hour oil changes. Make a fair offer. Smooth reving engine. Zero problems with it. Price depends on how you want it (FEAD, Intake Carb, Balancer, Oil Pan, Etc.,,,) With a change in cam and springs, (especially to a mechanical cam) some real hp could be wound out of this motor. Also have super low ground clearance flywheel and clutch setup with reverse mount starter. One event on new clutch. $1500 P/N INV-352-673-91 can be seen here http://www.taylor-race.com/items.cfm?category=Tilton%20Packages&subcategory1=Ford Jerico 4 speed road race trans. Does not have cooler pump in it, but has tailshaft setup for one. I never used it and had it removed as my trans temps were never excessive. Includes Shifter. $2k Complete deal - ready to drop in your car. $10k Drop 2 seconds a lap with the Jerico alone For detailed questions please contact me at rt1 at airmail dot net Quote Link to comment Share on other sites More sharing options...
