Paul Posted October 20, 2004 Share Posted October 20, 2004 H1 ITR's........ Are you guys using Accusumps? baffled pans? I've had some excessive oil spewing problems so I'm removing the Accusump. I'm leaving the Moroso pan, oil cooler and added another/breather catch can.... Paul Quote Link to comment Share on other sites More sharing options...
Andrie Posted October 20, 2004 Share Posted October 20, 2004 Paul, I've been running accusump in all my race cars. Been running them for about 2 years with no problem whatsoever. I'm guessing your problem is somewhere else. Maybe the moroso oil pan? I heard it was created with drag racing in mind. Quote Link to comment Share on other sites More sharing options...
Paul Posted October 20, 2004 Author Share Posted October 20, 2004 Anyone running just a stock pan and maybe a oil cooler successfully? Paul Quote Link to comment Share on other sites More sharing options...
Ron Carroll Posted October 20, 2004 Share Posted October 20, 2004 Paul, I have been running my accusump for 2 years on my 2nd gen Integra with stock pan and have had no problems, seems more like a venting problem for the crank case, building up too much pressure that can't get out fast enough so it forces oil out. Quote Link to comment Share on other sites More sharing options...
Andrie Posted October 20, 2004 Share Posted October 20, 2004 I like to add that I run them with srock pan as well. Quote Link to comment Share on other sites More sharing options...
vapor Posted October 20, 2004 Share Posted October 20, 2004 you aren't running too much oil in the engine? If it's overfilled, that's reason for the excess pressures building up and oil spewing out. Quote Link to comment Share on other sites More sharing options...
Paul Posted October 20, 2004 Author Share Posted October 20, 2004 Humm... I don't think over filling was the problem.... I even changed oil at the track to make sure I had the correct amount in... The funny thing was that the Accusump had pressure with the manual valve open and the air pressure at zero....it still read as having 80+psi Paul Quote Link to comment Share on other sites More sharing options...
FF lotus Posted November 1, 2004 Share Posted November 1, 2004 a possible solution for a second breather line is a vailiable from http://www.z10eng.com and it's basically an oil cap with an AN fitting attached Quote Link to comment Share on other sites More sharing options...
Paul Posted November 1, 2004 Author Share Posted November 1, 2004 I removed the Accusump and added a valve cover breather before the event this weeked and the problem is solved. Not one drop of oil anywhere all weekend! Thanks, Paul Quote Link to comment Share on other sites More sharing options...
SMSP Posted December 9, 2004 Share Posted December 9, 2004 H1 ITR's........ I'm leaving the Moroso pan, oil cooler and added another/breather catch can.... Paul When did aftermarket oil pans become legal in H1 or anywhere in HC? Quote Link to comment Share on other sites More sharing options...
civicrr Posted December 9, 2004 Share Posted December 9, 2004 from 2004 rules: 9.4 Oil System a) Oil coolers and remote oil filters may be used. b) Valve covers may be modified to accommodate a breather and/or filler. c) A pressure accumulator such as an Accusump may be used. Dry sump oiling systems are prohibited. d) Oil pans and all related items such as baffles, pickup, pump and scrapers are unrestricted. Quote Link to comment Share on other sites More sharing options...
Paul Posted December 10, 2004 Author Share Posted December 10, 2004 Quote Link to comment Share on other sites More sharing options...
