ukjonesie Posted April 12, 2009 Share Posted April 12, 2009 Just listed my trailer on eBay... You may need to copy and paste link in your browser. http://cgi.ebay.com/ebaymotors/2007-28ft-Enclosed-Trailer-10k-GVWR_W0QQitemZ160327751299QQcmdZViewItemQQptZMotors_Trailers?hash=item160327751299&_trksid=p4506.c0.m245&_trkparms=72%3A317%7C65%3A12%7C39%3A1%7C240%3A1318 2007 28ft Enclosed Trailer – 10,000lb GVWR This is a King Cobra 28 ft enclosed trailer; it is in great shape with no body damage. It’s finished inside with white walls and finished white ceiling. It has a large 48 inch side door with a large storage caddy – duel paper-roll holder and flip-down work surface. There are fitted cabinets with a side storage area and work surface in the nose. There is also a tire rack, but if you need the floor space, it can be removed easily. I will also include weight distributing hitch receiver, 10,000lb tension bars and brand new still in the box sway control set-up… (something like $300 worth of stuff!!) Specs: • 28 ft length • Two Axles, each at 5200lb rating • 16 inch on center walls and floor • ¾ plywood flooring • Beaver tail • Front stone guard • 48 inch side door with diamond plate finished step • Side door fitted storage caddy with paper roll holder and flip-down work surface • 4 5000lb “D” rings mounted in the floor • White finished walls and ceiling • Roof vent and two interior lights • Spring assist – easy lift rear load door • EZE lube hubs • 225/75-15 trailer tires in great shape This is a great trailer, I hate to sell it, but I won’t be using it for a while, so rather than just park it, somebody should get some use out of it… If needed, I will help with delivery once trailer is paid for. I’m willing to meet you up to a 500 miles maximum from my location for $1.30 a mile with a minimum fee of $100.00. (For example, if we meet 350 miles from Lake Orion, MI, delivery cost will be $455.00) Require full payment before delivery; will accept bank-to-bank wire transfer. Quote Link to comment Share on other sites More sharing options...
s2europa Posted April 29, 2009 Share Posted April 29, 2009 I see you ended the auction early. Does that mean the trailer is sold? Thanks, Dan Quote Link to comment Share on other sites More sharing options...
