hmongboy Posted November 9, 2004 Share Posted November 9, 2004 so how far can i go cutting away the metal sheet on the doors. can i just chop off the whole thing? also i need to know how to remove the window from a civic *ahem*mike*ahem*. Since i'm working on a 4 door, is it possible to cut out the rear doors also? Thanks Quote Link to comment Share on other sites More sharing options...
mikeski38 Posted November 10, 2004 Share Posted November 10, 2004 (edited) You are not allowed to gut the doors unless you install NASCAR style door bars. Also you are only allowed to install NASCAR doorbars on the driver's door. Therefor, you can only gut the drivers door. You can remove everything if you want, but I recommend leaving the factory side impact protection for added safety. Edited November 10, 2004 by Guest Quote Link to comment Share on other sites More sharing options...
civicrr Posted November 10, 2004 Share Posted November 10, 2004 Hey, coming out to Thunderhill this weekend? Mike Lock is correct, sort of. 4.10 Door Safety Bars In addition to meeting all the NASA CCR specifications for the roll cage, Honda Challenge Series cars must also meet the following additional specifications. At least one door bar must be used on both the driver and passenger sides. The drivers side window glass, window operating mechanism, inner door panel, and interior door latch assemblies may be removed, but the OEM side impact beam may not be removed or modified unless NASCAR-style bars (as defined in CCR) which extend to the outer door skin are added to the roll cage. It is highly recommend using a NASCAR style door bar for adequate side impact protection. Passenger side window glass, window operating mechanism, inner door panel, and interior door latch assemblies may be removed, but the OEM side impact beam may not be removed unless 2 bars are utilized in the cage design (i.e. 2 horizontal bars or X design). 4.11 Door Glass Driver and passenger side door glass must be removed or covered with a protective panel (stock is permitted). So...you can remove the door glass, tracks, motors, inner latch, the trim (plastic panel) & the inner panel (metal). If you have NASCAR bars on the driver's side, you can remove the oem impact beam on the driver's side. If you have two door bars on the passenger side, you can remove the impact beam. I left both of mine in for safety! Let me double check on the rear doors since it doesn't specify. IIRC, removal of door glass, track, motor & latch will be allowed. Quote Link to comment Share on other sites More sharing options...
mikeski38 Posted November 10, 2004 Share Posted November 10, 2004 gezzzz...way to get nit picky on me Quote Link to comment Share on other sites More sharing options...
hmongboy Posted November 10, 2004 Author Share Posted November 10, 2004 Hey, coming out to Thunderhill this weekend? T-hill is to far for me just to go watch =P Quote Link to comment Share on other sites More sharing options...
civicrr Posted November 10, 2004 Share Posted November 10, 2004 gezzzz...way to get nit picky on me ....well, that is why I get the big bucks. Hey, wait a minute, I don't get paid..... Quote Link to comment Share on other sites More sharing options...
