mwilson7 Posted November 30, 2004 Share Posted November 30, 2004 Can someone please tell me what an "upright" is when referred to in section 6.1D? Does 6.1D also mean that you can't modify the center differential for cooling? Does 6.1D also mean that you can't weld a bracket to the IRS cardle to mount a diff pump to? (if they are legal) Does the IRS referral in 6.2 mean that ANY IRS that I can come up with is legal in AIX? Quote Link to comment Share on other sites More sharing options...
racercosmo Posted November 30, 2004 Share Posted November 30, 2004 Can someone please tell me what an "upright" is when referred to in section 6.1D? ?An upright is the part that houses the rear wheel bearings and stub axles. Something such as this: Quote Link to comment Share on other sites More sharing options...
V8cobra99 Posted November 30, 2004 Share Posted November 30, 2004 The IRS unit in the 1999+ Cobra's do require Diff cooling, so I hope no rule is in place to limit that? The stock 8.8 Diff is alumininum and Steeda, MM, Griggs, Kenny Brown and others all told me if the car is raced, the stock Diff in the IRS will melt down. Therefore, I installed a KB diff cooler unit. Andy Quote Link to comment Share on other sites More sharing options...
mwilson7 Posted November 30, 2004 Author Share Posted November 30, 2004 So it would appear that the upright is the rear spindle. Quote Link to comment Share on other sites More sharing options...
racercosmo Posted November 30, 2004 Share Posted November 30, 2004 Not quite. It is what most people confuse as the spindle, but the 99-up Cobras do not use rear spindles. The hub is pressed into the rear bearing which is different than the fronts where a hub and bearing slide over a spindle. Quote Link to comment Share on other sites More sharing options...
Jeff F Posted November 30, 2004 Share Posted November 30, 2004 A more accurate term (at least in Ford-speak) would be a rear knuckle. Quote Link to comment Share on other sites More sharing options...
Members Jim P. Posted November 30, 2004 Members Share Posted November 30, 2004 Does anyone know if they plan to use IRS on the 2005 Mustang? Quote Link to comment Share on other sites More sharing options...
Guest Posted November 30, 2004 Share Posted November 30, 2004 Does anyone know if they plan to use IRS on the 2005 Mustang? What difference does it make? Quote Link to comment Share on other sites More sharing options...
Members Jim P. Posted November 30, 2004 Members Share Posted November 30, 2004 None that I know of - I was just personally curious - is it going to be on the Cobra in '05? PS. I might want to buy one - Quote Link to comment Share on other sites More sharing options...
Guest Posted November 30, 2004 Share Posted November 30, 2004 None that I know of - I was just personally curious - is it going to be on the Cobra in '05? PS. I might want to buy one - when you do let me know i'll give you an X plan # Quote Link to comment Share on other sites More sharing options...
Members Jim P. Posted November 30, 2004 Members Share Posted November 30, 2004 when you do let me know i'll give you an X plan # Thanks, I am thinking about one, might be a collector's item someday Right now I am concentrating on buying a turbo diesel dually 70's dually technology is only comfortable for short distances! Quote Link to comment Share on other sites More sharing options...
racercosmo Posted November 30, 2004 Share Posted November 30, 2004 I doubt it will be on the '05 Cobra because there is no such thing. Quote Link to comment Share on other sites More sharing options...
swhiteh3 Posted November 30, 2004 Share Posted November 30, 2004 The 2005 Mustang has a live (solid) axle. Right now SVT is predicting it's Cobra will be available in 2007. Quote Link to comment Share on other sites More sharing options...
mwilson7 Posted December 1, 2004 Author Share Posted December 1, 2004 So can anyone answer any of the other questions? Quote Link to comment Share on other sites More sharing options...
racercosmo Posted December 1, 2004 Share Posted December 1, 2004 MArk, there are less than a handful of people that can answer the other questions. All of us here can make our best guesses to the intent of the rule, but that doesn't help the guy who does it then is made illegal. Why don't you email Ryan or John? Quote Link to comment Share on other sites More sharing options...
Ted Schwartz Posted December 1, 2004 Share Posted December 1, 2004 Why don't you email Ryan or John? Please post the answer when you get it. Quote Link to comment Share on other sites More sharing options...
JWL Posted December 1, 2004 Share Posted December 1, 2004 Gentlemen- The picture Cosmo posted is indeed what we intended to be the "upright" for IRS purposes. To answer Mark's questions, 6.1(d) does not prohibit either modification he mentions. We are cool with you cooling the diff. As to the AIX question, knock yerselves out. You can indeed add any IRS rear system to the car within the other restraints of the rules. A specific example would be that it is kosher to add a Viper-spec Dana to a Fox body, so you can mix and match. Hope that helps and we are more than happy to answer rules questions on this forum, so fire them away when they come up. Please give us some time to respond as we've got a working group in place now so that we can discuss items before we render a decision. Thanks. -JWL Quote Link to comment Share on other sites More sharing options...
