p928sfan Posted November 30, 2004 Posted November 30, 2004 Unfortunately, due to personal circumstances I must sell my 944-SPEC car. 1986 Porsche 944 Spec car (#17) Engine and suspension setup by Chris Cervelli, formerly of Technodyne. Suspension--- KMR ProSeries camber plates 30mm torsion bars Weldmeister HD sway bars front and rear (22mm rear, 28 mm front) Yellow Koni’s all around 944 Adj Ride Height Kit , 52mm, 350# front Hypercoil Springs Engine -- Amsoil 20-50 used in car since rebuild Complete rebuild 10/28/2003 at Technodyne (has been to only 7 track days since that rebuild) Oil pan had temperature sensor attached and internal baffling mods made to prevent starvation. Car made 132 RWHP immediately after last rebuild. AC compressor removed (alternator moved down with adaptor) Catalytic converters removed. Straight pipe exhaust (have never had any noise issues at any track with this). Interior -- Safety Devices (from Stable Energies) bolt in 6-point cage (welded feet) I found this cage fit more snugly to the car frame than others, leaving more space inside for the driver. Cobra Monaco Seat (Black) CROW latch and Link 5-pt belts MOMO Model 80 Steering wheel with quick disconnect. Completely stripped interior, only dash remaining. Exterior – Gray with pink Dent in lower body behind rear driver’s side wheel. Was there when I bought the car, didn’t happen in race. Second set of phone dial wheels, with new Toyo’s bought in May 04. Only used 3 – 20 minute sessions. (no, they are not painted pink yet, either) Still have door glass, window motors, door skins + other assorted parts, if buyer is interested in them. Car is not registered for street use. Buyer to arrange transportation. (I have been using a tow hitch that bolts to the front bumper to get to and from local events. That’s open for discussion if buyer is interested.) Car has been quite competitive in the events I’ve attended. Definitely more driver’s fault than anything else You can look at my results off: http://members.rennlist.com/m758/944-spec.htm (Thanks Joe) My car is the pink nosed one in the middle of the top picture. I have times listed in both the AZ and the SoCal race reports. Also, you can see a picture in the "944 spec driver and Team listing" link on the same page. Asking $11K, obo Contact me via the following ways. Kevin Kane PM me on here or Email [email protected] Home Phone 623-362-1972 Cell Phone 602-751-2110 I can send additional pictures to interested people. _________________ Quote
Tim Comeau Posted January 5, 2005 Posted January 5, 2005 Kevin, Has the cage been welded to the A & B pillars? Quote
p928sfan Posted January 6, 2005 Author Posted January 6, 2005 No. It's just the standard "Safety Devices" bolt-in cage with the welded feet. No extra welding done on it. Quote
