Rule Change: Section 3.0 (GTS classing)
Shall GTS rules adopt the following...
52 members have voted
1. Shall GTS rules adopt the following...
1) The GTS classing rule used to be weight divided by only horsepower, and should still be. Adding the (HP+T)/2 handicap section was a mistake; get rid of it.3
2) Do not change the rule -- keep the (HP+T)/2 handicap as it exists.36
3) Change the rule to be weight divided by the average horsepower between the RPM of peak horsepower and 25% less RPM -- keeping most cars in the same class they are currently, but moving the current outliers to an appropriate class.5
4) The weight to power ratio is just an approximation of the acceleration capability of a car. For classing purposes, just measure the actual acceleration capability in seconds to reach a specified distance, then class the cars according to that.1
5) Change the rule to apply the (HP+T)/2 formula to all cars -- give a great boon to high RPM low torque engines.5
6) Whatever -- I do not care.1
7) None of the above.1
