Lemming Posted September 20, 2009 Share Posted September 20, 2009 In section 5 of the current rules it states that "Competitors may use any brand of dyno for certification, but all compliance runs at events will be made on a Dynojet ..." I believe that this rule should be changed and that all certifications must be based on a Dynojet as well. Under the current rules, one could use a mustang dyno, which produces lower HP numbers than a Dynojet to classify their car in a lower class. It is then necessary for a competitor to protest the individual in order to correct the issue in regions where dynos are never present at the track. Quote Link to comment Share on other sites More sharing options...
ianacole Posted September 20, 2009 Share Posted September 20, 2009 I've added a poll. For the sake of argument, I feel it could be of benefit to competitors that do not have a dynojet locally available, so long as they understand the consequences of using a non-dynojet model. Quote Link to comment Share on other sites More sharing options...
Lemming Posted September 20, 2009 Author Share Posted September 20, 2009 I've added a poll. For the sake of argument, I feel it could be of benefit to competitors that do not have a dynojet locally available, so long as they understand the consequences of using a non-dynojet model. If that's the case, why even get a dyno, just let them estimate their HP If someone does not have access to a dynojet, they can always race in GTSU as per the rules. Quote Link to comment Share on other sites More sharing options...
RSCoupe Posted September 21, 2009 Share Posted September 21, 2009 I vote NO. I need an AWD dyno for my car, and the Dynojet AWD dynos are few and far between, and those can be tough to get on, if at all. Quote Link to comment Share on other sites More sharing options...
cosm3os Posted September 21, 2009 Share Posted September 21, 2009 I agree. If you want (or have to) use something else, you take a chance. Such a rule would be as useless and problematic as mandating scale manufacturer. Quote Link to comment Share on other sites More sharing options...
Damon in STL Posted September 21, 2009 Share Posted September 21, 2009 I'd like to see the rule changed to only allow the Dynojet with an exclusion for AWD cars. It would cause me to go a little further to get to a Dynojet dyno sheet.....but, I really like to avoid any doubt or wondering if someone is classed wrong or not. Damon in STL Quote Link to comment Share on other sites More sharing options...
Lemming Posted September 21, 2009 Author Share Posted September 21, 2009 I vote NO. I need an AWD dyno for my car, and the Dynojet AWD dynos are few and far between, and those can be tough to get on, if at all. The proposed rule already applies to AWD cars (see section 5.1), which states that the certification for AWD cars must be done on a dynojet, otherwise you are in GTSU. Quote Link to comment Share on other sites More sharing options...
Keith Andrews Posted September 21, 2009 Share Posted September 21, 2009 If competitors are allowed to find a competitive advantage and chalk it up to convenience they will. To allow certified cars to choose the dyno that produces the lowest dyno numbers seems a little weak to me. Quote Link to comment Share on other sites More sharing options...
RSCoupe Posted September 22, 2009 Share Posted September 22, 2009 I vote NO. I need an AWD dyno for my car, and the Dynojet AWD dynos are few and far between, and those can be tough to get on, if at all. The proposed rule already applies to AWD cars (see section 5.1), which states that the certification for AWD cars must be done on a dynojet, otherwise you are in GTSU. You're right, so I request a change to allow alternate manufacturers. There are only around 3 AWD Dynojets around Chicago, and I couldn't get on any of them prior to our Putnam event the first weekend of October. So i am going to do my de-tuning on a Dyno Dynamics. So it looks like I'll be in GTSU. I guess I can turn the boost up... Quote Link to comment Share on other sites More sharing options...
Mike Simard Posted September 22, 2009 Share Posted September 22, 2009 Don't some non-Dynojet brands allow numbers to be reported with "Dynojet" correction? I'm not sure but think that may be the case. I agree that we should have a standard dyno brand but that might be an option for AWD cars if it exists. Quote Link to comment Share on other sites More sharing options...
Lemming Posted September 22, 2009 Author Share Posted September 22, 2009 Don't some non-Dynojet brands allow numbers to be reported with "Dynojet" correction? I'm not sure but think that may be the case.I agree that we should have a standard dyno brand but that might be an option for AWD cars if it exists. Yes, they do that at VIR but I would want to see the data showing how good the dyno actually predicts the dynojet results. As a scientist/researcher, I have spent quite a bit of time validating new biomedical instruments and I can tell you it takes many data points to come up with valid prediction equations. Quote Link to comment Share on other sites More sharing options...
ELEPHANT1 Posted September 22, 2009 Share Posted September 22, 2009 I'm sure this is a headache for someone but what about competitors being required to show what type of dyno their numbers come from? Such that in locations where one might use a dyno that produces lower numbers, thus a lower class, a competitor at a given event would know this as would the director or GTS person in charge. Perhaps it would alleviate some suspicion as to proper classification of a given car. Cheers. Quote Link to comment Share on other sites More sharing options...
911.racer Posted October 1, 2009 Share Posted October 1, 2009 Why not just go to claimed Hp and eliminate the need for an actual sheet. Ed Quote Link to comment Share on other sites More sharing options...
Lemming Posted October 1, 2009 Author Share Posted October 1, 2009 Why not just go to claimed Hp and eliminate the need for an actual sheet. Ed I'm not sure that there are many stock engines in GTS. Quote Link to comment Share on other sites More sharing options...
