Scany Posted January 8, 2010 Share Posted January 8, 2010 Just thought I'd share this. Last night I ordered the UUC raceshifter with the DSSR. I'm pretty excited to see how this will work out since I obviously need more precise shifter after my money shift last at Summit. I know there are cheaper options out there that work. UUC had a 15% off and free shipping and their shifters have a good reputation. I'll post back when I get it in the car and try it out. Of course all bushings gets replaced as well Anyone else want to share their shifter solutions? Quote Link to comment Share on other sites More sharing options...
dollar Posted January 8, 2010 Share Posted January 8, 2010 Thanks for the tip, Anders!! I have had a couple of close to missed-shift instances myself. I will read up on this as well. Quote Link to comment Share on other sites More sharing options...
Members Jon M. Posted January 8, 2010 Members Share Posted January 8, 2010 Guys, be careful with the agressive short shifters, they are fun for the street, but when driving in anger, I have found that I prefer to have a longer (stock) shift distance because it helps to ensure I am in the right gear. When you decrease the distance between the gates and the throws, you are reducing the margin of error to save you in the event of a brainfart. I have often found that when shifting into fourth gear between turns 8 and 9 at Summit, it is easier than I would like to find 2nd. Also, your trans only has so much capability in terms of syncing the gears when you shift, so your hand's ability to pull the level may not be the limiting factor. Please, don't take my comments the wrong way, I love SS'ers for the street, I just wanted to share my experiences as I have used them previously on the track as well. 6 weeks until 2010 KICKS OFF!!!! Quote Link to comment Share on other sites More sharing options...
laze1 Posted January 8, 2010 Share Posted January 8, 2010 I recommend race quality tranny and engine mount bushings, and shifter bushing rebuild to prevent "money shifts"...less engine/tranny flopping around will make better up and down shifts... Quote Link to comment Share on other sites More sharing options...
VaTechM3 Posted January 8, 2010 Share Posted January 8, 2010 Nice buy Anders...you should probably fix that motor first though I've got the Evo3 SSK with the DSSR and have very much enjoyed it for the entire season. Haven't had any issues. I also bought a clutch stop which I found to be very nice, but takes some trial and error to get it right...I'm still working on mine. I'd like to see how the race shifter compares to the Evo3 when you get your car back up and running. I'm tracking an engine down for you from a 325ia up in the NJ/NYC area that is like $3/400 with 93k on it if you're interested. Might save some time and money pulling yours all apart and repairing! Good luck with the install and enjoy! Quote Link to comment Share on other sites More sharing options...
dollar Posted January 8, 2010 Share Posted January 8, 2010 ^^^ Thanks for chiming in Andrew! I was considering the EVO3 with DSSR as well. Anders : You sure the DSSR with the racing short shifter will clear the guibo joint? I know the DSSR has a groove cut out on the bottom but the angle of the SR changes when using with the short shifter. Please confirm. Quote Link to comment Share on other sites More sharing options...
Scany Posted January 9, 2010 Author Share Posted January 9, 2010 Some new development in this case (as I am taking the head off the engine ): UUC don't have the raceshifter in stock and in no near future they said. I'm going to call them on Monday to see when it might be coming in. I'm pulling the trans while the head is off to get to those bolts a bit easier, so I thought the SSK should be added while the box is out. Taking the wise words from Jon and my friend Craig I'm starting to doubt if the whole SSK in a racecar is a good idea. I had it in my E30 and liked it. I also feel the throw is way too far stock in the E36, so I think I would benefit from a shorter throw, but maybe not too short. The shifter isn't too hard to change while the trans is in the car I guess, so I can always go back, or to another one. I think it's the bushings that's a pain to replace while it's in. Mani: I have not heard of any problems with the DSSR hitting anything. It should be further away as the connection point is higher. Or am I imagining this wrong? If the raceshifter won't be able to get here in time I'll try to cancel it and just get a DSSR for another shifter. I've heard good things about a $20 eBay shifter and the Z3 OEM shifter. The EVO3 is way pricey for me at this point. I believe the difference is the EVO3 uses a bearing and it's adjustable. I also agree, mounts and bushings is probably going to prevent miss shifting more than anything else. Now back to the garage to get that head off and see the damage... PS Andrew: I'm still interested in a replacement engine. I'm sure if I fix this I'll be able to break it again soon A backup would be handy. Quote Link to comment Share on other sites More sharing options...
1slowspec3 Posted January 15, 2010 Share Posted January 15, 2010 i got the z3 shifter and new tranny bushings when i got the car last year. i have had any close calls, so far so good. its def a lot shorter then stock and a lot more precise feeling. cant argue with the price i think like 75 for shifter and all the other new small pieces that go with it. stock felt like a truck to me Quote Link to comment Share on other sites More sharing options...
dollar Posted January 21, 2010 Share Posted January 21, 2010 i got the z3 shifter and new tranny bushings when i got the car last year.i have had any close calls, so far so good. its def a lot shorter then stock and a lot more precise feeling. cant argue with the price i think like 75 for shifter and all the other new small pieces that go with it. stock felt like a truck to me do you have a part # for this Z3 shifter? pelican parts is confusing the uneducated me. Quote Link to comment Share on other sites More sharing options...
1slowspec3 Posted January 22, 2010 Share Posted January 22, 2010 do you have a part # for this Z3 shifter? pelican parts is confusing the uneducated me. No im not sure of the part number, i do remember buying it from this website though. http://www.understeer.com/onlinestore-shifters.shtml i went with the one they say is a "40%" reduction. Quote Link to comment Share on other sites More sharing options...
dollar Posted January 22, 2010 Share Posted January 22, 2010 do you have a part # for this Z3 shifter? pelican parts is confusing the uneducated me. No im not sure of the part number, i do remember buying it from this website though. http://www.understeer.com/onlinestore-shifters.shtml" onclick="window.open(this.href);return false; i went with the one they say is a "40%" reduction. Cool, thank you, I'll do that. Quote Link to comment Share on other sites More sharing options...
Members Jon M. Posted January 22, 2010 Members Share Posted January 22, 2010 In my old Spec E30, the E36M3 shift fork was a reducer and could be used, but it also had a slight clearance issue which made 2nd gear (when shifting from 1st during a stand start) a little difficult to engage. If you install a Z3 or E36 M3 fork, make sure you try the car out before putting everything back together. You may find a little griding can go a long way to making your life easier later on. 4 WEEKS!!! Quote Link to comment Share on other sites More sharing options...
matt325 Posted January 23, 2010 Share Posted January 23, 2010 The "40% reduction" version from www.understeer.com is the one I went with. Works great and coupled with upgraded tranny mounts and engine mounts, I have not had any close calls with the shifts. Quote Link to comment Share on other sites More sharing options...
Scany Posted February 23, 2010 Author Share Posted February 23, 2010 Unfortunately UUC could not produce and ship the race shifter in time. They were sorry about it and was giving me a good deal to make up for it, but I decided to cancel the order. I think I will now go for the Z3M shifter at $55. Quote Link to comment Share on other sites More sharing options...
dollar Posted February 23, 2010 Share Posted February 23, 2010 I now have the 40% shifter and a DSSR from understeer.com. It should be in before March event. Quote Link to comment Share on other sites More sharing options...
Scany Posted February 24, 2010 Author Share Posted February 24, 2010 I now have the 40% shifter and a DSSR from understeer.com. It should be in before March event. That seems like a good alternative also. I read something about the Z3M shifter being very short and off centered. The E36 M3 shifter might be an alternative since it's not as short as the Z3M. Anyone know if that's the 40% that understeer is selling? Quote Link to comment Share on other sites More sharing options...
Scany Posted February 28, 2010 Author Share Posted February 28, 2010 I now have the 40% shifter and a DSSR from understeer.com. It should be in before March event. I ended up doing the same Quote Link to comment Share on other sites More sharing options...
dollar Posted March 1, 2010 Share Posted March 1, 2010 I now have the 40% shifter and a DSSR from understeer.com. It should be in before March event. I ended up doing the same Quote Link to comment Share on other sites More sharing options...
Scany Posted March 10, 2010 Author Share Posted March 10, 2010 Got the DSSR but it does not seem like it's the UUC one made of aluminium. The one I got looks different and seems to be stainless steel. How is yours Mani? Quote Link to comment Share on other sites More sharing options...
dollar Posted March 10, 2010 Share Posted March 10, 2010 Got the DSSR but it does not seem like it's the UUC one made of aluminium. The one I got looks different and seems to be stainless steel. How is yours Mani? I will take a closer look and let you know. Quote Link to comment Share on other sites More sharing options...
dollar Posted March 15, 2010 Share Posted March 15, 2010 Got the DSSR but it does not seem like it's the UUC one made of aluminium. The one I got looks different and seems to be stainless steel. How is yours Mani? Mine looks like Aluminum. It is a little more shiny than the pictures on the UUC website, yes. Quote Link to comment Share on other sites More sharing options...
