Stang107 0 Posted January 12, 2010 Share Posted January 12, 2010 Can anyone point me to a source a get a remote type shifter that will work with a Pro 5.0 shifter on a T5 in my 1994 Mustang? Over the winter the engine has been set back 1" and the pedals and seat have been signifcantly moved back as well. Thanks.... Marty Fabrick Quote Link to post Share on other sites
edhunter 0 Posted January 12, 2010 Share Posted January 12, 2010 Marty; I have one I may be interested in selling. It's made to put a T5 in a early model mustang, but I used in in my 88 track car. It def. shortens the shifting. It's made by restomod I think. Anyway I'm setting my engine back 1" this winter, but my seating/pedal position is stock - my main hoop won't let me move my seat back. Moving the tranny back an inch will probably mean I don't need the shifter any longer. I can send pics if you'd like. ed Quote Link to post Share on other sites
bmrracing 0 Posted January 13, 2010 Share Posted January 13, 2010 I tried all types of ways to make a remote shifter work well and the shifter built by Mustangs Plus (restomod) in California is the only one that really works well. It is a little pricey but is really worth it. Quote Link to post Share on other sites
Holster Maker 0 Posted January 13, 2010 Share Posted January 13, 2010 I agree. I have been using one for several yrs and love it. Well worth it! Quote Link to post Share on other sites
swhiteh3 0 Posted January 13, 2010 Share Posted January 13, 2010 Mr Tone? Paging BPT... Quote Link to post Share on other sites
stevepoe 0 Posted January 13, 2010 Share Posted January 13, 2010 I ran this one year .worked pretty well http://www.mustangsplus.com/tech/speedshifter/index.html Quote Link to post Share on other sites
TurboShortBus 1 Posted January 23, 2010 Share Posted January 23, 2010 I tried all types of ways to make a remote shifter work well and the shifter built by Mustangs Plus (restomod) in California is the only one that really works well. It is a little pricey but is really worth it. At $189, it is priced a lot lower than the $300 that a fabricator (who has made them for AI/AIX cars in the past) was quoting me, but there were some differences in the design and construction for that additional $111 (double shear pivots vs single shear, etc.). Here is the shifter setup in the Tone/Wilson car, aka shifter porn (mega-huge photo shoplifted from http://www.On-TrackPerformance.com; EDIT: fabricated by Brian Tone): Mark Quote Link to post Share on other sites
swhiteh3 0 Posted January 24, 2010 Share Posted January 24, 2010 Yup, that's the set-up I was talking about, and the set-up I run in my AI car. It's VERY nice. I was hoping if there was enough demand Brian might consider doing another run of them... Quote Link to post Share on other sites
Members Ed M. 0 Posted February 18, 2011 Members Share Posted February 18, 2011 Yup, that's the set-up I was talking about, and the set-up I run in my AI car. It's VERY nice. I was hoping if there was enough demand Brian might consider doing another run of them... So, did he cause I need one...? If not, guess I'll go with the Mustangs Plus one. I like the one Brian did though - looks like it allows for more adjustability... Ed Quote Link to post Share on other sites
AJ Hartman 0 Posted February 18, 2011 Share Posted February 18, 2011 while were on this topic, anyone have any pictures of how they set the pedals back? Quote Link to post Share on other sites
TurboShortBus 1 Posted February 19, 2011 Share Posted February 19, 2011 while were on this topic, anyone have any pictures of how they set the pedals back? I'm trying to work on that setup in my 2004 Mustang, while keeping the stock pedal assembly and Hydroboost. If it's not feasible to extend the Hydroboost linkage (it's starting to look that way), then I might just slap a Wilwood/Tilton/Coleman floor-mount pedal on the floorpan about 8" rearward of the stock brake pedal and connect the two with Heim-jointed linkage, while making my own gas pedal and maybe converting to a hydraulic clutch with an external slave cylinder. Do you have any stock items that you're trying to keep while you set your pedals back? Mark Quote Link to post Share on other sites
b_tone 0 Posted February 20, 2011 Share Posted February 20, 2011 while were on this topic, anyone have any pictures of how they set the pedals back? We didn't, if you look at the pic that was attached and scroll to the right you'll see the Tilton setup for manual brakes and hydraulic clutch that we used. Quote Link to post Share on other sites
99cobra2881 1 Posted April 2, 2011 Share Posted April 2, 2011 Here's my stab at a remote shifter. The only problem I forsee is the upright on the tri-ax shifter is too tall in stock form. I'm thinking about trimming the top bolt hole/portion off the tri-ax. Then using the bottom two bolt holes to attach the shifter arm, Hopefully this will decrease shifter throw some. I cut the grooves in the handle to add grip. Even with gloves on the grooves really work. Turning down the shifter upright and cutting it to length. I plan to test fit the handle in the car then weld the bracket to the trans tunnel. Quote Link to post Share on other sites
AJ Hartman 0 Posted April 7, 2011 Share Posted April 7, 2011 nice. keep us updated. Quote Link to post Share on other sites
99cobra2881 1 Posted April 22, 2011 Share Posted April 22, 2011 Shifter is done and in the car. Worked great at my SCCA double driver school last weekend!! Here is the final product. I just row the thing fore and aft to change gears, the springs in the tri-ax really help make upshifts easy. I cut the top hole of the tri-ax upright off and used the bottom two holes to attach the shifter. Doing this shortened up the shifter throws and made a big difference. Quote Link to post Share on other sites
gregscott 0 Posted October 6, 2014 Share Posted October 6, 2014 Do you have a parts list and some specs/dimensions etc? Thanks Greg Quote Link to post Share on other sites
99cobra2881 1 Posted October 6, 2014 Share Posted October 6, 2014 PM sent. I can build more of these if anyone wants one? 1 Quote Link to post Share on other sites
John0330 0 Posted May 31, 2019 Share Posted May 31, 2019 On 10/6/2014 at 11:12 PM, 99cobra2881 said: PM sent. I can build more of these if anyone wants one? Hi did you sell it already?! Quote Link to post Share on other sites
Hayden25 0 Posted July 7, 2019 Share Posted July 7, 2019 On 10/7/2014 at 5:12 AM, 99cobra2881 said: PM sent. I can build more of these if anyone wants one? My buddy got a '95 Mustang project we will be working on right after we finished installing the brake kit and moto metal rims on the current truck project. He's looking for remote shifter as well. It would be cool if you have. Quote Link to post Share on other sites
Dwilbun 0 Posted September 8, 2020 Share Posted September 8, 2020 99cobra2881, If you are making any more remote shifters. I will gladly buy one. Quote Link to post Share on other sites
