camaro68 Posted January 23, 2010 Share Posted January 23, 2010 here are my specs of my car im building... i may run TT but may want to race too.. where would i fit in? i will be in ca az ut nv ... thanks guys.. 68 camaro shwartz extreem full chassis w link trianglated suspention. qa1 coil overs all the way around. tubular upper and lower arms... 16 point cage 095 dom tubing 1 3/4 .....considered tube chassis car has fire system and battery enclosure and fuel cell has its own area with protection bars too with shut off.. sb chevy 350 with 400hp hooked up to tk0 600 5 speed trans , winters 9in rear w moser floating axels and billet caps and aluminum 3rd member wilwood 6 piston calipers and 13in rotors in front ... 4 piston wilwood and 13 rotors rear with air ducts for all brakes. z06 wheels with 330 45 18 rear 285 45 18 front.. lexan windows front and rear .. list goes on and on...hope this helps Quote Link to comment Share on other sites More sharing options...
jimbow Posted January 24, 2010 Share Posted January 24, 2010 Read the Time Trial rules. Available from the NASA time trial site. Add up all your points. Don't know how much your car weighs but its probably SUR (TTS, TTU or TTR) depending on HP/wt ratio. Quote Link to comment Share on other sites More sharing options...
IGZOSTD Posted January 24, 2010 Share Posted January 24, 2010 camaro68, Check out the ST rules, with some weight adjustments you could go ST2. Add up the points on the car classifacation forms in TT, PT they are the same Quote Link to comment Share on other sites More sharing options...
camaro68 Posted January 24, 2010 Author Share Posted January 24, 2010 thank you , will look into it. Quote Link to comment Share on other sites More sharing options...
