heel_touge Posted February 4, 2010 Share Posted February 4, 2010 specifically why this will not pass a tech inspection. I say, sub harness is wrapped over seat and no back brace. I also think the main hoop is at far too much of an angle. i could be wrong though. are there any specific rules (i didnt see any) about running an oem seat with harnesses and a roll bar with door bar like that? Quote Link to comment Share on other sites More sharing options...
ianacole Posted February 4, 2010 Share Posted February 4, 2010 Tech inspection for what - racing (heaven forbid) or HPDE (I hope)? Quote Link to comment Share on other sites More sharing options...
heel_touge Posted February 4, 2010 Author Share Posted February 4, 2010 lets say.... BOTH! Quote Link to comment Share on other sites More sharing options...
obzezzed350 Posted February 4, 2010 Share Posted February 4, 2010 I pity the fool who uses harnesses on OEM SEATS(without harness guides)!!! Quote Link to comment Share on other sites More sharing options...
RSCoupe Posted February 4, 2010 Share Posted February 4, 2010 Just about everything with that fails tech for racing. Look at the CCR. It's a bad design all around, and dangerous, even for HPDE. Quote Link to comment Share on other sites More sharing options...
mrc24x Posted February 4, 2010 Share Posted February 4, 2010 The only thing I see: 1) Stock seat with a "roll bar" and shoulder harness. (the harness can slide off your shoulders, the tube frame stock seat will/can collapse) 2) The bends of the main hoop are not in the same plane and the angle is borderline. 3) Main hoop is mounted to the floor pan? (Hopefully someone can post the link to the Mustang roll over with the cage punched through the floor) At a minimum remove the cage and 5 point belts. Use the stock harness and airbag setup if you want to do HPDE's. (compared to what's in the picture) Copy pages 75-80 in the CCR and take it to a cage builder if you plan on racing. Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted February 4, 2010 Share Posted February 4, 2010 for racing - needs an additional door bar, halo, a-pillar bars Quote Link to comment Share on other sites More sharing options...
ninetyfourintegra Posted February 4, 2010 Share Posted February 4, 2010 Diagonal? 2 Door Bars? In addition to the above posts. Quote Link to comment Share on other sites More sharing options...
heel_touge Posted February 4, 2010 Author Share Posted February 4, 2010 im in a rather heated discussion with a bunch of drag racers about how this is far more dangerous than having no cage at all. ugh, frustrating to say the least. Quote Link to comment Share on other sites More sharing options...
Raznkane Posted February 5, 2010 Share Posted February 5, 2010 Would the T tops be a problem? Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted February 5, 2010 Share Posted February 5, 2010 im in a rather heated discussion with a bunch of drag racers about how this is far more dangerous than having no cage at all. ugh, frustrating to say the least. arguing on the internet with some people is about as futile as trying to draw a smell. Good luck! Quote Link to comment Share on other sites More sharing options...
obzezzed350 Posted February 5, 2010 Share Posted February 5, 2010 I kinda have to agree with the drag racers(doesnt happen very often )...that setup looks very poorly crafted in my opinion Quote Link to comment Share on other sites More sharing options...
heel_touge Posted February 5, 2010 Author Share Posted February 5, 2010 I kinda have to agree with the drag racers(doesnt happen very often )...that setup looks very poorly crafted in my opinion no the drag racers were saying that cage setup is safer in a street car than no cage at all in a high speed collision/rollover etc. Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted February 5, 2010 Share Posted February 5, 2010 with no padding at all on it... riiiiiggghhhtt. Maybe if they're wearing their helmet while they're street racing Quote Link to comment Share on other sites More sharing options...
jimbow Posted February 7, 2010 Share Posted February 7, 2010 Would the T tops be a problem? For HPDE, probably not. IIRC the CCR says they need to be in place and can't be glass. Preffered it to cover them up. I sgree thats a horrible roll bar. Too many bends, and I didn't see any rear supports. Just imagine rolling on the roof and the front of the bar continuing to bend the way it is bent in the picture - BAM right on your head. Quote Link to comment Share on other sites More sharing options...
nape Posted February 7, 2010 Share Posted February 7, 2010 I think the worst thing about that bunch of tubes welded together is that I don't see any back stays (kickers). I wouldn't even call that a roll bar. Quote Link to comment Share on other sites More sharing options...
bossman429 Posted February 7, 2010 Share Posted February 7, 2010 My oppinion without looking at codes - Factory seats need to be used with factory seatbelts. Shoulder harness comes down more than 10 degrees over the seat it should be perpendicular to the vertical position of the driver (more like a sideways L instead of a upside down V) Angle on the main hoop is horrendous I dont see any back down tubes. No padding (at least on side and top bar) And last but not least - its ugly Quote Link to comment Share on other sites More sharing options...
