Steven Rea Posted January 13, 2005 Posted January 13, 2005 This car won the 2004 POC STS Championship for the spec-944 class (944GSR), as well as holds the track record (clockwise) at the Streets of Willow. year - 1985.5 It was a very tough decision, but I need to sell it to support an ls-1 powered 944 project. This is a strong class that is growing tremendously, leading to challenging races with excellent competition, while maintaining wonderful comraderie. Honestly, it's tough to leave, as the guys are a great group to race with. This car has had every performance modification within the limit of the rules, with the exception of the chip. This includes: (all with 9 or less track days on them) shaved head koni shocks all around front spring perches (adjustable) 400# front springs ground control camber plates 30mm rear torsion bar weltmeister sway bars delrin torsion plate bushings delrin or poly bushings throughout suspension manual rack which replaced power one lsd - phantom grip short fifth gear stainless steel brake lines Hawk Black pads Slotted rotors - front straight-pipe (no cat) with glass pack exhaust Additionally: new spring centered clutch all new engine seals replaced only 9 race-days ago (head gasket, cam-tower gasket, all front seals, oil pan gasket, all bottom seals) new timing belt new rod bearings new low temp fan switch new low temp thermostat new front tie rod linkage (incl. ends) mobil1 15/50w used always 6pt. custom weld-in cage with nascar door on driver's side and an X on passenger - seat back brace Ultrashield Rally Sport aluminum seat Ultrashield - top of the line padded harnesses (they're much more comfortable when strapped in) Momo steering wheel see car# 50 for a photo at Joe's site: http://members.rennlist.com/m758/DriverListing.htm This car holds the Streets of Willow Track Record (clockwise) at 1:16.9 , on its first day driven in that direction. With it's proven track results and full performance set-up, its new owner can know that they have the car necessary to run at the front...which leaves it up to the driver. Asking price $12,750 Please contact me at (310)913-0742 with any questions or offers. Steve Quote
