SpecMiata 1.8 for price of 1.6...Save $$$
’94 1.8 SpecM for the price of a 1.6!
Price lowered from $22k for quick sale due to new business venture. Save $$$!
Description
Car details:
• '94 1.8 SpecM, white body/blue top w/white stripes, Dec '03 completed
• JT Designs welded cage w/Nascar bars on driver side (and reinforced welds by Andy Anderson of McMillin off-road racing)
• Re-built motor from the inside out, new everything, valve job by Speed Specialties/Larry Holt, build by Jim Jordan/Protomotive (World Challenge team), inspected thoroughly and expertly maintained by Rush Motorsport
• Balanced and flowed injectors
• AWR/Mazdacomp radiator
• New plugs/wires from Mazdacomp
• Hawk Blues front/rear
• Steel brake lines
• Full spec suspension w/adj rear bar
• New tie rods
• New alignment bolts
• Mazdacomp Adjustable end links
• Corner balanced by Rush, perfect spec weight 2175 at 1/4 tank w/o driver
• Torsen LSD (with new seals and fluid), orig diff incl.
• Mazdacomp 4-puck clutch
• New clutch master and slave
• New shift tower fluid and boot
• New front hubs (and re-packed even from new)
• Stripped interior, painted w/grey rustoleum
• Sparco drivers seat, new Sparco 6pt camlock harness
• OE Miata passenger seat, new Sparco 6pt camlock harness
• Sparco flat-bottom steering wheel w/Sparco Quick-release
• MyChron XG 3+ Gold Data Acqu unit mounted in gauge pod incl. CD and manual
• Fire extinguisher mounted on ctr tunnel (within reach, but full arm movement)
• Wink mirror (5-panel)
• Mesh window net (small weave for easier vision)
• Brand new top quality windshield (original had small chips)
• New wiper blades and refinished wiper arms
• Fuel test port installed
• Test pipe and custom Rush Motorsport exhaust --no muffler, exits after subframe brace, 2nd full system available separately--exits stock location and has Magnaflow muffler,
original cat included for smog checking (this car is registered and plated in CA)
• Kill switch mounted in OE antenna hole
• TD Race wheels 30mm offset w/RA1s, run only 2 wknds (2nd set avail separately w/RA1s mounted), 17mm
special lugs and standard Mazdacomp lugs included
• OE 14 Hollowback spoke '94 Miata alloys w/Goodyear street tires for street driving avail separately
• Orig OE jack and spare avail
• "R" Chin spoiler from Mazdacomp
• Box of new spares: hoses, gaskets, seals, plugs, wires, etc avail separately
• 2 spare New Miata nose/fr bumper covers avail separately, never mounted, OE paint, 1 blue, 1 black avail separately
• 2 sets sideview mirrors, 1 set Blue non-power included, 1 set White power avail separately
• Spare color-matched blue rollbar padding, both low and high density avail separately
• Spare airbox avail separately
• Clean title, never wrecked, one of the nicest SpecMs
• Drop-in windows for trailering to keep car sealed/locked from weather/people avail separately
• Both SCCA and NASA annual techs, both logbooks
• AMB transponder hard-wired into nose
• All required graphics already applied
• Receipts up the whazoo, flowbench printout, etc
• New $80 Mazda shop manual avail separately
• Spare OE dash gauge cluster avail separately
• Swepco and Redline fluids throughout, even spares of this available!
• Fast, solid car, no excuses, no expense spared rare 1.8 powered car
• Car finished on podium at Cal Speedway in only 3rd race with rookie driver!
• YOU can Podium or Win with this car!
$16.5k for racecar, ready to race, already prepped!
(replicate this car and you’ll spend $25-29k)
Buy the car, and I'll make you a smoking deal on all the spares for an unbeatable package deal!
AND…if you also need a tow vehicle/family SUV…
'98 Ford Expedition Eddie Bauer loaded with all options, CD chgr, dual air, power seat, roof rack, tow pkg, 5.4l Vortec V8, dual exahust, Magnaflows, fully serviced, new brakes, axles/seals, solid, dependable, luxurious, tows powerfully, 100kmi. I'd keep it but my wife wants something more glamorous--oh boy!
$9750
I know of shippers who can deliver the racecar to you anywhere in the US for a good price, or if you buy the SUV too, there's a U-haul place nearby with car haulers for $49/day and they're really easy to deal with. I'll give you my new hitch ball and plug-and-play wiring adapter too if you get the Expedition.
Call Dave:
858-259-2262 office
San Diego
[email protected]
http://www.specmiata.com/classifieds/detail.php?siteid=2027[/img]
