Capt Squid Posted May 5, 2010 Share Posted May 5, 2010 If so how did it change the handling? Thanks Quote Link to comment Share on other sites More sharing options...
mcmmotorsports Posted May 5, 2010 Share Posted May 5, 2010 I had them out of necessity. Car handled fine, just couldn't get the ride height any lower than 5". Quote Link to comment Share on other sites More sharing options...
944-Spec#94 Posted May 5, 2010 Share Posted May 5, 2010 It should not change the handling as spring rate is spring rate. If you can't get the ride height you want then that could have an impact. Quote Link to comment Share on other sites More sharing options...
Sterling Doc Posted May 5, 2010 Share Posted May 5, 2010 I would echo both of the above. Those were my experiences running a 10" spring. I now run an 8" spring. 7" springs had the opposite problem- car ran lower than I wanted, even with the adjustment collars all the way up. Quote Link to comment Share on other sites More sharing options...
krystar Posted May 5, 2010 Share Posted May 5, 2010 eric/joe/michael, have you found any reason to look for springs that have smaller coil diameter for more compression length before binding? or is that not an issue? Quote Link to comment Share on other sites More sharing options...
mcmmotorsports Posted May 5, 2010 Share Posted May 5, 2010 I would say it is not an issue....but that is just me. Quote Link to comment Share on other sites More sharing options...
944-Spec#94 Posted May 5, 2010 Share Posted May 5, 2010 eric/joe/michael, have you found any reason to look for springs that have smaller coil diameter for more compression length before binding? or is that not an issue? No. When running a 944 spec car at the ride heights we do you will bottom the koni shock to the bump stop before you coil bind the spring. Quote Link to comment Share on other sites More sharing options...
Sterling Doc Posted May 5, 2010 Share Posted May 5, 2010 Shock travel is the limiting factor, not springs. Quote Link to comment Share on other sites More sharing options...
