JerryW Posted June 25, 2010 Share Posted June 25, 2010 I'm having weird results when I hookup the rpm input on my TraqSync cable. I have the module set to C for Coil and ran a cable straight to the neg side of the coil. With the User Data set via Traqview to 4 cylinders it is showing consistantly low. If I set it to 8 cyls then it appears more accurate but doesnt run full range. What cylinder number do those of you who have traqmate and RPM connections have set ? Am I missing anything obvious ? Thanks Guys Quote Link to comment Share on other sites More sharing options...
schwank Posted June 26, 2010 Share Posted June 26, 2010 I just fired mine up to check but have to connect to the display unit to get that data. Will do that at the shop tomorrow. But thanks to your post I just downloaded the files to update both the software and the display unit. Quote Link to comment Share on other sites More sharing options...
JerryW Posted June 26, 2010 Author Share Posted June 26, 2010 Yea - I need to do the software update too.Thanks for reminding me Quote Link to comment Share on other sites More sharing options...
schwank Posted June 28, 2010 Share Posted June 28, 2010 So I checked my settings and on the car setup I have it on 4 cylinders, warning at 6400, red at 7000. I assume you can set the weight to whatever but I currently have mine at 2700. I have the full unit with the display and the coil wire running to the sensor unit analog adapter. Quote Link to comment Share on other sites More sharing options...
JerryW Posted June 28, 2010 Author Share Posted June 28, 2010 Thanks for checking. I'll pull the data from the weekend and compare what got recorded. (The results I was seeing was in the driveway reving the engine in neutral using the Traqmate as a tach). Quote Link to comment Share on other sites More sharing options...
