bradze Posted August 26, 2010 Share Posted August 26, 2010 some people tell me it helps and im still having issues with fade, dont know if i should take off or not Quote Link to comment Share on other sites More sharing options...
JSG1901 Posted August 26, 2010 Share Posted August 26, 2010 I would get rid of them...they block airflow to the brakes. Unless, of course, they DIRECT air to the brakes, in which case I'd keep 'em. Quote Link to comment Share on other sites More sharing options...
911.racer Posted August 26, 2010 Share Posted August 26, 2010 It is not the shields, it is the pads. Get yourself some good Hawk pads like the DTC's from Andrew Racing. Dump the shields too, though. Ed Quote Link to comment Share on other sites More sharing options...
Enzo Posted August 26, 2010 Share Posted August 26, 2010 The purpose of brake dust shields is to prevent DTV (Disk Thickness Variation) caused by dust/dirt/debris hitting your rotor during the normal environmental conditions found during street driving. Eliminating the dust shields will increase the risk of developing DTV, which ultimately causes brake judder & steering wheel nibble. (Trust me, if vehicle manufacturers could save the cost of getting rid of these, they would...) As far as racing - get rid of them if they are not helping your brake cooling. For the street - your call... On the other hand, if you are already replacing your rotors frequently due to track use, or not really concerned with steering wheel vibration, then it probably doesnt matter.... Quote Link to comment Share on other sites More sharing options...
bradze Posted August 27, 2010 Author Share Posted August 27, 2010 thanks, yeah i know what they're for, i go back and forth about taking them off or not. its only 2 bolts so i might just take em off when i change to race pads for track days. i run raybestos st43s then switch to something street friendly so im not replacing rotors all the time Quote Link to comment Share on other sites More sharing options...
KTL Posted August 27, 2010 Share Posted August 27, 2010 For a tracked car, if you've got the means to put cooling hoses to the brakes? By all means do it. Made a huge difference on my past 911 car. So if you can get even a miniscule improvement by removing the splash shields then you should do it. Anything you can do to keep the pad in its temp operating range and not overheat is going to extend the life of your pads and rotors. However i've noticed that removing them can make for longer braking distances when it's wet on the street. I removed them on my street car (BMW 5 series) and found that the exposure in the rain caused a noticeable difference in brake feel. It felt like brake fade for longer than i'd like, until the pads could swipe the rotor clear of water. Might just be the ceramic low dust compound i'm using (Axxis Deluxe), but nonetheless it was a noticeable difference that I did not like. So I put them back on since it's only a street car. There's a reason why they put them on there! Quote Link to comment Share on other sites More sharing options...
