ff2skip Posted December 20, 2010 Share Posted December 20, 2010 (edited) QUESTION: Does your region require convertibles to run top down without regard to weather unless a hardtop is installed? Please answer only if you are sure of your region's enforced rule. Thanks, Skip * Mid-Atlantic requires tops be down. * Southeast - no requirement except Barber Motorsports Park * Midwest - no requirement Edited December 22, 2010 by Guest Quote Link to comment Share on other sites More sharing options...
whoahstu Posted December 20, 2010 Share Posted December 20, 2010 I see many in the Great Lakes region running with the soft top up. Is there a reason to require that the top be down? I've often wondered. Quote Link to comment Share on other sites More sharing options...
ff2skip Posted December 21, 2010 Author Share Posted December 21, 2010 I see many in the Great Lakes region running with the soft top up. Is there a reason to require that the top be down? I've often wondered. I believe the concern would be that of a driver or passenger being impaled by the top frame in the unfortunate case of a rollover. Our region also requires that all convertibles must have aftermarket roll protection. We know this to go beyond NASA's national guidelines. I/we have no doubt that Chris Cobetto and his team do everything in their power to host the safest possible events. I'm more interested, however, in the "top down" enforcement- more specifically, if any other regions have the same requirement. Quote Link to comment Share on other sites More sharing options...
Lucid Moments Posted December 22, 2010 Share Posted December 22, 2010 The Southeast also requires top down running regardless of weather. Quote Link to comment Share on other sites More sharing options...
Members Jim P. Posted December 22, 2010 Members Share Posted December 22, 2010 The Southeast also requires top down running regardless of weather. Actually the Southeast leaves the choice up to the occupants of the car - they can run top up or down*. There are pros and cons for either position. *except at Barber Motorsports Park - top down only Quote Link to comment Share on other sites More sharing options...
ff2skip Posted December 22, 2010 Author Share Posted December 22, 2010 The Southeast also requires top down running regardless of weather. Actually the Southeast leaves the choice up to the occupants of the car - they can run top up or down*. There are pros and cons for either position. *except at Barber Motorsports Park - top down only Thanks for the response, Jim. Quote Link to comment Share on other sites More sharing options...
whoahstu Posted December 23, 2010 Share Posted December 23, 2010 Are the top-down regions requiring that the lowered softop be secured? I think the important part is that the top is secure, regardless of its position. Quote Link to comment Share on other sites More sharing options...
ff2skip Posted December 23, 2010 Author Share Posted December 23, 2010 Are the top-down regions requiring that the lowered softop be secured? I think the important part is that the top is secure, regardless of its position. If a top is not motorized(Miatas), then I'd say that would be a good point. Quote Link to comment Share on other sites More sharing options...
Lucid Moments Posted December 25, 2010 Share Posted December 25, 2010 The Southeast also requires top down running regardless of weather. Actually the Southeast leaves the choice up to the occupants of the car - they can run top up or down*. There are pros and cons for either position. *except at Barber Motorsports Park - top down only Was that always the rule, or did it change at some point? Quote Link to comment Share on other sites More sharing options...
aCab Posted December 30, 2010 Share Posted December 30, 2010 The Southeast also requires top down running regardless of weather. Actually the Southeast leaves the choice up to the occupants of the car - they can run top up or down*. There are pros and cons for either position. *except at Barber Motorsports Park - top down only Was that always the rule, or did it change at some point? I ran top down and up at Roebling last may. I much preferred top up, plus from what I hear, times decrease because it has more aero advantages. Quote Link to comment Share on other sites More sharing options...
roger69 Posted January 8, 2011 Share Posted January 8, 2011 Required or not, nothing is more fun than running with your top down! Sound quality on your video becomes an issue, though.... Quote Link to comment Share on other sites More sharing options...
