Bark3rd Posted December 21, 2010 Share Posted December 21, 2010 Trying to finish my car for the season and discovered a jagged hole in the side of my Sparco America (fiberglass FIA) seat where the inside bolt on the upper door bar poked through. Can I just reinforce it with some glass and resin? Im wondering what to do about the bolt too, not sure how it could be moved (bolt in Spec cage-Spec 7 car Quote Link to comment Share on other sites More sharing options...
DanSTi Posted December 21, 2010 Share Posted December 21, 2010 With a hole in the shell like that, I would replace it. Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted December 21, 2010 Share Posted December 21, 2010 replace the seat take the bolt out of the door bar and weld the bar in. Go do the same for the rest of the cage while you're at it! Quote Link to comment Share on other sites More sharing options...
mbuskuhl Posted December 21, 2010 Share Posted December 21, 2010 replace the seat take the bolt out of the door bar and weld the bar in. Go do the same for the rest of the cage while you're at it! Take half that advice. Replace the seat but you can't weld the cage bars for SRX7. Roll cage: Brand: Autopower Model: 83591 RX (1 ½” DOM material or 1 ¾” ERW). Notes; Material and construction defined by the SCCA GCR, ERW cages are not permitted in any car registered after 1/1/03. All cars must use specified roll cage which shall not be modified except for mounting window net and seat belt mounting brackets, and will only be bolted (not welded) in place. Metal plates may be used to reinforce the floor pan of the car at the roll cage mounting points. These plates may be welded in place. Plates must follow the specification in GCR 18.2.8.B, and may not be more than ¼” thick. Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted December 21, 2010 Share Posted December 21, 2010 You can in PTF, so there! there's gotta be a way to swap that bolt around so it doesn't rub. It looks to me like even a metal seat wouldn't hold up to that Quote Link to comment Share on other sites More sharing options...
mbuskuhl Posted December 21, 2010 Share Posted December 21, 2010 You can in PTF, so there! You can do alot of things in PTF that you can't do in SRX7 Quote Link to comment Share on other sites More sharing options...
Bark3rd Posted December 21, 2010 Author Share Posted December 21, 2010 I have the same car and cage as the rest of you guys, anyone ever had an issue with the drivers side upper door bar bolts touching the seat? Quote Link to comment Share on other sites More sharing options...
sscguy Posted December 22, 2010 Share Posted December 22, 2010 Can you alter your seat mount to move the seat more towards the center of the car? Quote Link to comment Share on other sites More sharing options...
Bark3rd Posted December 22, 2010 Author Share Posted December 22, 2010 I just remembered that the previous owner was really tall, the seat position was so far back I could barely reach the pedals and Im 6'2" (this also would explain why the rest of the Spec 7 guys arent having this problem). Relocating the seat forward (which I planned to do anyway) will allow the seat to clear that bolt. Thanks for helping me figure this out! Duh! Quote Link to comment Share on other sites More sharing options...
Bark3rd Posted February 11, 2011 Author Share Posted February 11, 2011 Thanks, thats exactly what I did. The stock floor in these cars is like aluminum foil. Heres a few pics my excellent cage builder sent me of the reinforcements and seat back brace he made for me (Matt Lemmons/Lemco Motorsports) if you want to see how it turned out. Scroll to page two to see the schweet seat back brace he fabbed up. http://www.lemcomotorsports.com/svm/g84/ When I grab the seat through the window and try to shake it now, its like granite-no movement whatsoever. Now I can drive crazee.... Quote Link to comment Share on other sites More sharing options...
