bedlam Posted January 9, 2011 Share Posted January 9, 2011 We have added a Z06 to our list of projects at the shop. The car was wrecked, we've rebuilt it and it's now licensed and drivable however...the Z06 driver information center is scrolling: SERVICE ABS, SERVICE ACTIVE HANDLING, SERVICE TRACTION CONTROL. When the Snap On guy connected his scanner to the port the screen was reading: RR SPEED SENSOR ERROR, RF SPEED SENSOR ERROR. We did replace the right rear wheel bearing assembly. Does any one know if, I can pull a fuse and simply disable the whole mess until I have time to fix? I am afraid the problem may be in the wiring. Thanks/Greg Quote Link to comment Share on other sites More sharing options...
drivinhardz06 Posted January 9, 2011 Share Posted January 9, 2011 double check to make sure the hub/bearing wiring connectors are plugged in? Quote Link to comment Share on other sites More sharing options...
bedlam Posted January 10, 2011 Author Share Posted January 10, 2011 We have double checked the wiring connectors but...that does not always mean the connections are good. Does any one know if, there is a delete code for the errors. We're wondering if, every time we start the car up, it shows us the history. Thanks/Greg Quote Link to comment Share on other sites More sharing options...
drivinhardz06 Posted January 10, 2011 Share Posted January 10, 2011 if the connectors (and the wiring harness extensions on the front) are good, double check all your body grounds Quote Link to comment Share on other sites More sharing options...
brkntrxn Posted January 10, 2011 Share Posted January 10, 2011 Have you driven the car since doing all of the work? Any time I disconnect my battery and/or any of the TC/AH nannies, I get those messages until I drive the car a mile or two. Then the computer resets itself and everything is good. -Kevin Quote Link to comment Share on other sites More sharing options...
bedlam Posted January 11, 2011 Author Share Posted January 11, 2011 Yes, we have driven the car and every time we start it, the codes pop up however....the battery was either discounted or was requiring a charge before starting so, I am now wondering if, that had something to do with it. It seem very hard to stay up to date with the advancement of these systems. Greg Quote Link to comment Share on other sites More sharing options...
jason Posted January 17, 2011 Share Posted January 17, 2011 Put a fresh battery in and keep it on a trickle charger. Low batteries cause these sorts if problems and make it very hard to trouble shoot. Quote Link to comment Share on other sites More sharing options...
