Josh Ashcroft Posted March 19, 2005 Share Posted March 19, 2005 I've got a few black streeks on my hood from stray marbles. I tried elbow grease, but some of the spots are less cooperative than others? Anybody got any good tricks (or products) for getting this stuff off? Thanks Quote Link to comment Share on other sites More sharing options...
JoeLee Posted March 19, 2005 Share Posted March 19, 2005 In the cleaner/wax section of most auto stores you can find Goof-Off or Goo-Gone. It's for removing sap, bugs and tar from cars. Works fine. Quote Link to comment Share on other sites More sharing options...
jp99gt Posted March 20, 2005 Share Posted March 20, 2005 Although the chemical products do work, they remove the wax finish off your car. I always try detailing clay first (fine grade), and that usually works well for marbles since the racing rubber is softer than street rubber. And the clay won't remove your finish. By the way, the primary petroleum ingredient in those chemical cleaners is just kerosene. If you have that at home, it will work well. Then refinish your paint after. Quote Link to comment Share on other sites More sharing options...
Mikecolosprings Posted May 10, 2006 Share Posted May 10, 2006 I know This Is Just A Little Late, lol. But It's Still Usefull Info Summit or Jegs Sells Stuff you Spray on Before You Go To the Track Then Just Wipe Everything off. It's for Drag Cars When They do There Burnouts, but it will work for anything Quote Link to comment Share on other sites More sharing options...
GAC Posted May 10, 2006 Share Posted May 10, 2006 After repeated testing, Goof Off works better than Goo Gone, from what I've found, but yes, it will kill the paint luster. Just do a wax job after if you'd like. Quote Link to comment Share on other sites More sharing options...
CMC#64 Posted May 10, 2006 Share Posted May 10, 2006 I used good ole WD-40 and it took the marks off my car... then I sprayed the area right afterwards with a "Quik Detailer" type wax... looks great Quote Link to comment Share on other sites More sharing options...
PDenbigh Posted May 10, 2006 Share Posted May 10, 2006 "Rejex", the NASA Mid Atlantic sponcer, seems to have a good product. Don't have a website or contact info though, maybe someone can chime in? Quote Link to comment Share on other sites More sharing options...
white_2kgt Posted May 10, 2006 Share Posted May 10, 2006 For the really stubbon stuff I use a good rubbing compound. Only do this about once a year right before rewaxing. Quote Link to comment Share on other sites More sharing options...
thebionicman Posted May 10, 2006 Share Posted May 10, 2006 http://www.corrosionx.com/rejex.html I use the stuff on my entire car. It works great on the windows, body and wheels. Quote Link to comment Share on other sites More sharing options...
white_2kgt Posted May 10, 2006 Share Posted May 10, 2006 http://www.corrosionx.com/rejex.html I use the stuff on my entire car. It works great on the windows, body and wheels. so you put that stuff on BEFORE the rubber sticks? It is suppose to make it easier to wipe off? Quote Link to comment Share on other sites More sharing options...
Frank Corkran Posted May 11, 2006 Share Posted May 11, 2006 so you put that stuff on BEFORE the rubber sticks? It is suppose to make it easier to wipe off? What, you haven't been listening during the NASA-MA morning meetings? Available at Jeff's trailer. Yes, you apply it beforehand so dirt/rubber/bugs won't stick. Quote Link to comment Share on other sites More sharing options...
white_2kgt Posted May 11, 2006 Share Posted May 11, 2006 so you put that stuff on BEFORE the rubber sticks? It is suppose to make it easier to wipe off? What, you haven't been listening during the NASA-MA morning meetings? Available at Jeff's trailer. Yes, you apply it beforehand so dirt/rubber/bugs won't stick. The what meetings? I guess I'll have to stop by and take a look at that stuff this year, rubbing this crap off is starting to get old. Quote Link to comment Share on other sites More sharing options...
dwc Posted May 11, 2006 Share Posted May 11, 2006 I use regular 'ole carnuba car wax, takes it right off and lays down a new coat of wax at the same time. I think I'm using Mother's right now. Someone told me about this, and I said no way in hell that'll work.....but I'll be damned if it don't! Daniel Quote Link to comment Share on other sites More sharing options...
PtBy Posted May 15, 2006 Share Posted May 15, 2006 Use any of the cleaner/waxes you find at the auto parts store. I use Mequires cleaner/wax. Cleans them black marks off and waxes as you go. Quote Link to comment Share on other sites More sharing options...
ddg Posted May 15, 2006 Share Posted May 15, 2006 I use WD-40, it will probably disolve the wax, but it won't hurt the paint! Quote Link to comment Share on other sites More sharing options...
Gairloch Posted May 17, 2006 Share Posted May 17, 2006 This is what I intend to do when I've got a paint job I care about: http://www.protint.com/QuickPeel.ivnu Quote Link to comment Share on other sites More sharing options...
Eric J. Posted May 17, 2006 Share Posted May 17, 2006 I've found that just keeping a good wax finish on the car makes the rubber easy to remove. That's a bit of a pain for a race car, but my old HPDE car was a good street car and I always kept it well waxed. The rubber could just be rubbed off with a finger or towel. Quote Link to comment Share on other sites More sharing options...
