chrumck Posted June 2, 2011 Share Posted June 2, 2011 Hi, I'll be rebuilding the stock 8.8 in my 06 Mustang GT and I was thinking about some point-free upgrade to the diff cover. So, can you tell me which of these would cost points?: - aluminum differential cover with diff cap supports - diff cooler - drain bung welded into the stock cover Thanks! Tom Quote Link to comment Share on other sites More sharing options...
SNAKBITN Posted June 3, 2011 Share Posted June 3, 2011 All of thoses are free mods and since you have it all broken down I would change the gear. Robert Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted June 3, 2011 Share Posted June 3, 2011 which free mods cover all that stuff? Quote Link to comment Share on other sites More sharing options...
SNAKBITN Posted June 3, 2011 Share Posted June 3, 2011 I haven't seen any points acessed to those mods. Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted June 3, 2011 Share Posted June 3, 2011 it isn't listed in either section, so that means...? I do feel the cover modifications should be freebies fwiw. I am not in charge though Quote Link to comment Share on other sites More sharing options...
TurboShortBus Posted June 3, 2011 Share Posted June 3, 2011 - aluminum differential cover with diff cap supportsIMO, this is "snake oil." Are you sure that it's necessary? - diff coolerThis is the closest thing I can find, although it's in the Engine freebie section and not Drivetrain freebie: c. Engine 12) Oil systems and coolers other than added dry sump Although a diff cooler could be somewhat beneficial, are you sure that it's necessary? Rehagen's Continental Challenge Mustangs run them, but they are also on track for a couple of hours at a time. - drain bung welded into the stock coverAlthough I don't see it mentioned in the rules, I wouldn't have a problem if this showed up (even though "if it doesn't say that you can do it, then you can't do it" typically applies), as the only real advantage it gives you is saving $5 on every diff fluid change by not having to buy another tube of RTV. Mark Quote Link to comment Share on other sites More sharing options...
chrumck Posted June 3, 2011 Author Share Posted June 3, 2011 - aluminum differential cover with diff cap supportsIMO, this is "snake oil." Are you sure that it's necessary?Mark I thought of if as a way of getting the drain plug and adding some cooling through aluminum and webbing such covers have. That's actually the only mod I was thinking about. I added the rest to broaden the subject. So, is it a point mod or not? Quote Link to comment Share on other sites More sharing options...
TurboShortBus Posted June 3, 2011 Share Posted June 3, 2011 Well, if we take it to the limit of the rules, there is this sentence at the top of page 2 of the TTA-TTF classification forms: Some parts that are produced by aftermarket manufacturers as generic replacement parts may not require a points assessment provided that: they are the same size and shape, and have the same functional characteristics as the OEM part, and that they provide no significant improvement in performance, longevity, or reliability. By adding cooling to the diff with that cover, it could be argued that you are improving performance, longevity, and/or reliability. Additionally, those covers are marketed to add strength with the cap supports, which also improves performance, longevity, and/or reliability. Since this specific modification is not currently addressed in the rules, my initial interpretation would be that you cannot perform it, based on this: If a performance modification is not specifically allowed by the rules, it is prohibited. Additionally, note that there are several varieties of 8.8" differential covers from other models and sub-models that can be swapped onto Mustangs; I'm interested to see if/how these are considered as modifications. For those of you who are members (and can see the photos), refer to this thread on Corner-Carvers.com: http://www.corner-carvers.com/forums/showthread.php?t=23526&highlight=differential+covers I suggest that you email Greg G. directly for his determination, as it is final and will overrule any regional interpretations. Include links, photos, etc. for an accurate response. Mark Quote Link to comment Share on other sites More sharing options...
chrumck Posted June 3, 2011 Author Share Posted June 3, 2011 I think I found the cover I'd prefer the most, its FRPP M-4033-K which looks like this: Uploaded with ImageShack.us It has no advantage except for oil cooling and a place to tap a drain plug. I wonder if Greg would let it slip. Quote Link to comment Share on other sites More sharing options...
dans2k Posted June 7, 2011 Share Posted June 7, 2011 I don't think we can go down the dangerous path of people modifying under car aero for free! I mean one person changes their diff cover next thing you know everyone will be running diffuser shaped diff covers and ground effects tunnel diff covers Quote Link to comment Share on other sites More sharing options...
chrumck Posted June 7, 2011 Author Share Posted June 7, 2011 I don't think we can go down the dangerous path of people modifying under car aero for free!I mean one person changes their diff cover next thing you know everyone will be running diffuser shaped diff covers and ground effects tunnel diff covers Or, God forbid, hardtop shaped differential covers. Quote Link to comment Share on other sites More sharing options...
jason Posted June 7, 2011 Share Posted June 7, 2011 I don't think we can go down the dangerous path of people modifying under car aero for free!I mean one person changes their diff cover next thing you know everyone will be running diffuser shaped diff covers and ground effects tunnel diff covers Dammit there's $5000 worth of carbon fiber down the drain. Quote Link to comment Share on other sites More sharing options...
Varkwso Posted June 10, 2011 Share Posted June 10, 2011 I don't think we can go down the dangerous path of people modifying under car aero for free!I mean one person changes their diff cover next thing you know everyone will be running diffuser shaped diff covers and ground effects tunnel diff covers Dammit there's $5000 worth of carbon fiber down the drain. I can use it in TTS I will buy it from you cheap.... Quote Link to comment Share on other sites More sharing options...
